DIY TT isolation
mikeyb128
Would like to know the vinyl gurus thoughts. I know I will be told to wall mount my TT but I don't have the luxury. I think my GF would flip if I mounted the TT to the living room wall.
Thinking of using either butcher block or a piece of granite under the TT followed by sorbothane cones or pads. Maybe even rubber bumpers. I also have ebony spike feet and stainless ball bearings. I'm wanting to experiment and hear others thoughts. I can pretty much stomp on the floor and get no noise. Any tapping of the audio rack and I get the "bong, bong" through the speakers.
I did just upgrade my ikea rack to a free tv stand I got from a friend. Has solid wood end caps, steel frame and tempered glass shelves with suction cups between the glass and steel frame. Very heavy, even heavier loaded up.
Looking for budget tweaks, so let's keep it under a hundred bucks. Or no bucks if it's not worth it.
2 channel:
Theater:
Theater:
2 channel:
Theater:
Focal Aria 926,905,CC900, SVS PB ultra x2. Pioneer Elite SC85, Oppo BDP93, Panamax M5400PM, Minix neox6, Nordost Blue heaven LS power cables. -
Here is some info from a post I made earlier this year....hope it helps...
"As far as the TT is concerned...I was planning to wall mount, but as I looked at the project more closely...it just wasn't going to be feasible.
So I came up with an idea and it worked. #5 vibrapods on the feet of the audio rack, large sorbothane balls on top of the rack for the first shelf to sit on, mini sorbothane balls between the two shelves and #2 vibrapods under the TT feet. I know that's a lot of messing around, but I am able to jump and stomp with NO skips. I was stomping so hard I thought pictures were going to start falling off the walls
2 ChannelTurntable - VPI Classic 2/Ortofon 2M BlueAmplification - Rogue Audio Cronus Magnum II, Parks Audio Budgie PhonoSpeakers - GoldenEar Triton 17.2 Home TheaterDenon AVR-X3300W; Rotel RMB-1066; Klipsch RP-280F's, Klipsch RP-450C, Polk FXi3's, Polk RC60i; Dual SVS PB 2000's; BenQ HT2050; Elite Screens 120"Man CaveTurntable - Pro-Ject 2.9 Wood/Grado GoldAmplification - Dared SL2000a, McCormack DNA 0.5 DeluxeCD: Cambridge AudioSpeakers - Wharfedale Linton 85th Anniversary; LSiM 703; SDA 2A -
Essentially, I just stacked those shelves with sorbothane balls or vibrapods (doesn't really matter which) in between them.
It made a significant difference regarding footfalls. (I also put a set of vibrapods under the entire entertainment stand)2 ChannelTurntable - VPI Classic 2/Ortofon 2M BlueAmplification - Rogue Audio Cronus Magnum II, Parks Audio Budgie PhonoSpeakers - GoldenEar Triton 17.2 Home TheaterDenon AVR-X3300W; Rotel RMB-1066; Klipsch RP-280F's, Klipsch RP-450C, Polk FXi3's, Polk RC60i; Dual SVS PB 2000's; BenQ HT2050; Elite Screens 120"Man CaveTurntable - Pro-Ject 2.9 Wood/Grado GoldAmplification - Dared SL2000a, McCormack DNA 0.5 DeluxeCD: Cambridge AudioSpeakers - Wharfedale Linton 85th Anniversary; LSiM 703; SDA 2A -
The idea I may be running with is similar to yours. Going to use a 2 inch thick 6kg piece of Boucher board with sorbothane hemispheres stuck to the bottom of each corner. Trying to figure out if butcher block or granite will be better. Thanks @hochpt212 channel:
Theater:
Sandbox with floating butcher block or marble slab feasible?
It definitely is. Just as long as it's WAF enough.2 channel:
Theater:
I am still using these Magic Erasers as they are too dangerous for cleaning a stylus.
I am not kidding these are like dead mush and cheap too -
I do exactly what you suggested, a thick slab of butcher block and vibration pads under it. Works great.
Good music, a good source, and good power can make SDA's sing. Tubes make them dance. -
From my research Turns out granite is very resonant?2 channel:
Theater:
First level, that is where I am using the magic erasers under the butcher block and then vibrapods under an mdf piece and then the TT is sitting on those little blue/black squares. It wont pass a stomp test, my floors are like a drum but none of the vibration reaches the TT. I can feel it deminish as you go up each level. -
afterburnt wrote: »I do exactly what you suggested, a thick slab of butcher block and vibration pads under it. Works great.
I believe we have the same TT as well. Teac right?2 channel:
Theater:
Yes I think so and I am not kidding about the erasers, they really deaden vibration. I get more ambient resonance to the TT than what comes through the rack. I sit a stress ball on the dust cover and it mostly kills it.
I built a sand box for my project. Can't say it helped much. The floors are pretty springy in my 45 year old house though.Oh, Listen here mister. We got no way of understandin' this world. But we got as much sense of this bird flyin in the sky. Now there is a lot that bird don't know, but it don't change the fact that the world is happening to him all the same. What I am tryin to say is, is that the course of your life, well its changing, and you don't even see it- Forest Bondurant
Ordered this one from Amazon
https://www.amazon.ca/gp/aw/d/B000TFVTQK/ref=ox_sc_act_image_2?ie=UTF8&psc=1&smid=A3DWYIK6Y9EEQB
And some sorbothane hemispheres in 50 duro.
And boy that butcher block is puuurrdddyyy
2 channel:
Theater:
That will look great. Nice work.2 ChannelTurntable - VPI Classic 2/Ortofon 2M BlueAmplification - Rogue Audio Cronus Magnum II, Parks Audio Budgie PhonoSpeakers - GoldenEar Triton 17.2 Home TheaterDenon AVR-X3300W; Rotel RMB-1066; Klipsch RP-280F's, Klipsch RP-450C, Polk FXi3's, Polk RC60i; Dual SVS PB 2000's; BenQ HT2050; Elite Screens 120"Man CaveTurntable - Pro-Ject 2.9 Wood/Grado GoldAmplification - Dared SL2000a, McCormack DNA 0.5 DeluxeCD: Cambridge AudioSpeakers - Wharfedale Linton 85th Anniversary; LSiM 703; SDA 2A
I'd recommend the one I got over the one you're recommending. Product details have yours at 2" thick. The one I got is 3.5" thick. For the extra few bucks you get a much heavier board.
I just received a 24x18x3 Cutting Board last week, I'm using it as a TT base also (my table has a big footprint) I will be isolating it with some Sorbothane pads.
I was so impressed with the quality of the Cutting Board (Michigan Maple brand) I have two smaller ones coming that I'm going to use as amp stands.
I definitely agree. But that board shipped to Canada with conversion would be around 160 bucks! Trying to keep this around 100$ cad. I scowered the earth for a board that's big enough.2 channel:
Theater:
As in earth I meant Canada. Now use 4 sorbothane hemispheres or 3? Guessing 3 will be better.2 channel:
Theater:
Make sure to get a size that is proper for the weight you plan on supporting. That will make a difference if you go with 3 vs 4.2 ChannelTurntable - VPI Classic 2/Ortofon 2M BlueAmplification - Rogue Audio Cronus Magnum II, Parks Audio Budgie PhonoSpeakers - GoldenEar Triton 17.2 Home TheaterDenon AVR-X3300W; Rotel RMB-1066; Klipsch RP-280F's, Klipsch RP-450C, Polk FXi3's, Polk RC60i; Dual SVS PB 2000's; BenQ HT2050; Elite Screens 120"Man CaveTurntable - Pro-Ject 2.9 Wood/Grado GoldAmplification - Dared SL2000a, McCormack DNA 0.5 DeluxeCD: Cambridge AudioSpeakers - Wharfedale Linton 85th Anniversary; LSiM 703; SDA 2A -
Good call. Mine support up to 14 pounds each. TT and butcher block = around 25 pounds.2 channel:
Theater:
This is what I ended up with. Turned out to be a very worthwhile mod for about 100 bucks. Oiled the board up with orange oil, and looks great! Sounds even better! No noise!
2 channel:
Theater:
Me too. I said oiled board. What an animal.2 channel:
Theater:
I keep seein and thinkin oil the broad up....Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 *
SCompRacer wrote: »I keep seein and thinkin oil the broad up....
Going to new heights of offended-ness. Happy B'day BTW... -
No hope for me....thx, just a regular day, had to work.Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 *
I still think a good used oh...175/70R13 with a slab on it would work well...just me though.
Lol, girl friend might not like that ken, she is tolerant enough with my audio related habits.2 channel:
Theater:
Good idea. Camo, she won't even see it. Blends right in. Orrrr black paint....2 channel:
Theater:
