DIY TT isolation
Would like to know the vinyl gurus thoughts. I know I will be told to wall mount my TT but I don't have the luxury. I think my GF would flip if I mounted the TT to the living room wall.
Thinking of using either butcher block or a piece of granite under the TT followed by sorbothane cones or pads. Maybe even rubber bumpers. I also have ebony spike feet and stainless ball bearings. I'm wanting to experiment and hear others thoughts. I can pretty much stomp on the floor and get no noise. Any tapping of the audio rack and I get the "bong, bong" through the speakers.
I did just upgrade my ikea rack to a free tv stand I got from a friend. Has solid wood end caps, steel frame and tempered glass shelves with suction cups between the glass and steel frame. Very heavy, even heavier loaded up.
Looking for budget tweaks, so let's keep it under a hundred bucks. Or no bucks if it's not worth it.
2 channel:
Theater:
  • mikeyb128
    mikeyb128 Posts: 2,885
    nbrowser wrote: »
    Used tire with a granite slab on top? :)
    Definitely the cheapest way!
    2 channel:
    Theater:
  • hochpt21
    hochpt21 Posts: 5,423
    Here is some info from a post I made earlier this year....hope it helps...
    "As far as the TT is concerned...I was planning to wall mount, but as I looked at the project more closely...it just wasn't going to be feasible.
    So I came up with an idea and it worked. #5 vibrapods on the feet of the audio rack, large sorbothane balls on top of the rack for the first shelf to sit on, mini sorbothane balls between the two shelves and #2 vibrapods under the TT feet. I know that's a lot of messing around, but I am able to jump and stomp with NO skips. I was stomping so hard I thought pictures were going to start falling off the walls :)"
  • hochpt21
    Essentially, I just stacked those shelves with sorbothane balls or vibrapods (doesn't really matter which) in between them.
    It made a significant difference regarding footfalls. (I also put a set of vibrapods under the entire entertainment stand)
  • mikeyb128
    hochpt21 wrote: »
    The idea I may be running with is similar to yours. Going to use a 2 inch thick 6kg piece of Boucher board with sorbothane hemispheres stuck to the bottom of each corner. Trying to figure out if butcher block or granite will be better. Thanks @hochpt21
    2 channel:
    Theater:
  • mikeyb128
    ZLTFUL wrote: »
    Sandbox with floating butcher block or marble slab feasible?
    It definitely is. Just as long as it's WAF enough.
    2 channel:
    Theater:
  • afterburnt
    afterburnt Posts: 7,892
    edited December 2015
    I am still using these Magic Erasers as they are too dangerous for cleaning a stylus.
    I am not kidding these are like dead mush and cheap too
  • nspindel
    nspindel Posts: 5,343
    I do exactly what you suggested, a thick slab of butcher block and vibration pads under it. Works great.c9kshfjtcf7d.jpeg
  • nspindel
  • mikeyb128
    From my research Turns out granite is very resonant?
    2 channel:
    Theater:
  • afterburnt
    nspindel wrote: »
    First level, that is where I am using the magic erasers under the butcher block and then vibrapods under an mdf piece and then the TT is sitting on those little blue/black squares. It wont pass a stomp test, my floors are like a drum but none of the vibration reaches the TT. I can feel it deminish as you go up each level.
  • mikeyb128
    afterburnt wrote: »
    nspindel wrote: »
    I believe we have the same TT as well. Teac right?
    2 channel:
    Theater:
  • afterburnt
    Yes I think so and I am not kidding about the erasers, they really deaden vibration. I get more ambient resonance to the TT than what comes through the rack. I sit a stress ball on the dust cover and it mostly kills it.
  • jeremymarcinko
    I built a sand box for my project. Can't say it helped much. The floors are pretty springy in my 45 year old house though.
  • mikeyb128
    Ordered this one from Amazon
    https://www.amazon.ca/gp/aw/d/B000TFVTQK/ref=ox_sc_act_image_2?ie=UTF8&psc=1&smid=A3DWYIK6Y9EEQB
    And some sorbothane hemispheres in 50 duro.
    And boy that butcher block is puuurrdddyyy :smile:
    2 channel:
    Theater:
  • hochpt21
    That will look great. Nice work.
  • nspindel
    mikeyb128 wrote: »
    I'd recommend the one I got over the one you're recommending. Product details have yours at 2" thick. The one I got is 3.5" thick. For the extra few bucks you get a much heavier board.
  • Mike Reeter
    Mike Reeter Posts: 4,315
    I just received a 24x18x3 Cutting Board last week, I'm using it as a TT base also (my table has a big footprint) I will be isolating it with some Sorbothane pads.
    I was so impressed with the quality of the Cutting Board (Michigan Maple brand) I have two smaller ones coming that I'm going to use as amp stands.
  • mikeyb128
    nspindel wrote: »
    mikeyb128 wrote: »
    I definitely agree. But that board shipped to Canada with conversion would be around 160 bucks! Trying to keep this around 100$ cad. I scowered the earth for a board that's big enough.
    2 channel:
    Theater:
  • mikeyb128
    As in earth I meant Canada. Now use 4 sorbothane hemispheres or 3? Guessing 3 will be better.
    2 channel:
    Theater:
  • hochpt21
    mikeyb128 wrote: »
    Make sure to get a size that is proper for the weight you plan on supporting. That will make a difference if you go with 3 vs 4.
  • mikeyb128
    hochpt21 wrote: »
    mikeyb128 wrote: »
    Good call. Mine support up to 14 pounds each. TT and butcher block = around 25 pounds.
    2 channel:
    Theater:
  • mikeyb128
    This is what I ended up with. Turned out to be a very worthwhile mod for about 100 bucks. Oiled the board up with orange oil, and looks great! Sounds even better! No noise!
    2 channel:
    Theater:
  • ken brydson
    ken brydson Posts: 9,072
    mikeyb128 wrote: »
    I'm offended...
  • mikeyb128
    Me too. I said oiled board. What an animal.
    2 channel:
    Theater:
  • ken brydson
    mikeyb128 wrote: »
    You said it again! REPORTED!!
    SCompRacer Posts: 9,214
    I keep seein and thinkin oil the broad up....
  • ken brydson
    SCompRacer wrote: »
    Going to new heights of offended-ness. Happy B'day BTW...
    No hope for me....thx, just a regular day, had to work.
  • mikeyb128
    nbrowser wrote: »
    I still think a good used oh...175/70R13 with a slab on it would work well...just me though.
    Lol, girl friend might not like that ken, she is tolerant enough with my audio related habits.
    2 channel:
    Theater:
  • mikeyb128
    nbrowser wrote: »
    mikeyb128 wrote: »
    nbrowser wrote: »
    Paint the tire? Lol
    Good idea. Camo, she won't even see it. Blends right in. Orrrr black paint....
    2 channel:
    Theater:
