Audioquest Black Lab Sub Cable
Anyone have experience with these AQ sub cables? I re-organized my equipment cabinet and ordered a couple 2m cables. They arrived yesterday, but now that I took a look at them in person, they look kinda low quality vs. my other sub cables (AQ Black Thunder & Blue Jeans Cables LC-1). Thanks
Sony 83A80L TV and Roku Ultra
Denon 3800
Parasound HCA-2205A
SVS Prime towers, center channel and bookshelfs (side surrounds)
Atmos: Mirage Nanosats x 4
Turbo MFW-15 x 2
Panasonic DP-UB820
APC H15
Morrow MA4 & AQ Cobra IC's, AQ Midnight speaker cables
  • mantis
    mantis Posts: 17,374
    You purchased a entry level cable. It's still a good quality sub cable. I will do it's job exactly how it should and get all the Signal at that length to the Subwoofer.
    I'm willing to be it's overall sound quality will compete or beat both of your other sub cables even at it's entry level.
    I don't sell that cable I start at the Irish Red and go up.
    Dan
  • mufsoman
    mufsoman Posts: 636
    Thanks Dan. Yea, I know its entry level. These were 50% of the price for the AQ Black Thunder cables I bought from Audio Advisor. Just second guessing myself if I'm sacrificing any performance for cost....
    Denon 3800
    Parasound HCA-2205A
    Turbo MFW-15 x 2
    Panasonic DP-UB820
    APC H15
  • mantis
    No such thing with Audioquest cables
    Dan
  • Upstatemax
    Upstatemax Posts: 2,735
    edited November 2015
    I use on in my HT.
    Works and sounds very good to me!
    I swapped back and forth with an Irish Red cable from my Fathers system, I could not tell any difference...
  • For a 2 meter RCA sub-woofer cable it doesn't matter much what coax you use. But for a long cable (maybe 10 meters) the Blue Jeans LC-1 is the first choice.
  • mufsoman
    mufsoman Posts: 636
    Yep, I think I'm going to install these Black Lab Cables this weekend and give them a trial run. I should be able to do a A/B comparison with the other cables, so I'll test and confirm. Thanks for all the input!!!
    Denon 3800
    Parasound HCA-2205A
    Turbo MFW-15 x 2
    Panasonic DP-UB820
    APC H15
