Polk Vintage Products Info Page???
Inspector 24Inspector 24 Posts: 1,228
edited March 2016 in Vintage Speakers
Where did it go? I can't find it anywhere on the main site at Polkaudio.com. Nor can google it seems... Is it gone?
I truly hope not, the wealth of information all in one spot was awesome and very handy. So, anybody know where they're hiding it?
Down
RTiA9 - CSiA6 - FXiA6 - Dual HSU VTF-15H Mk2
Sim2 D60 - Dragonfly 106" Panny 500
Up
LSi15 LSiC - RX-V3000
Post edited by PolkTeam on
  • tonybtonyb Posts: 31,642
    edited November 2014
    as far as I can tell, it's gone....and on purpose. However we do have the "vintage" section on the main page of the forum if you scroll down.
    B&k 1430
    Tad 803 speakers
  • 5.1 System:
    Sharp Aquos 37" LCD
    Front: SRS-3.1TL
    Center: CS400i
    Surround: Monitor 10B
    PSW10 subwoofer
    Onkyo PR-SC886P Pre/Pro
    NAD T955 5 channel power amplifier
    Technics SL-1710 MK2 turntable
    Audio-Technica AT14Sa cartridge
    NAD 106 pre-amp
    Oppo BDP-103 Blu-Ray
    2014 MacBook Pro 2.8 GHz
    2.0 Office System:
    Monitor 10A (Peerless)
    Outlaw 1050 receiver
    Parasound HCA-1000A power amp
    MacPro
  • Jim, that's awesome! Thank You!
    TonyB, why would they do it on purpose??
    Down
    Up
  • cnhcnh Posts: 13,310
    And yet ONE MORE TIME (perhaps the fourth or fifth time), I ask: WHY ISN'T THIS A STICKY YET?
    cnh
  • KennethSwaugerKennethSwauger Moderator Posts: 6,846
    In the future just send me a message asking me to make something an "announcement". If it seems fitting, I will.
    "They thought we were too loud, but shoot, I had four army blankets folded over my amp, and the volume level was on 2. I'm used to playin' on 10!" S.R.V.
  • Sorry, didn't realize this had been answered somewhere else, haven't been on much since the big forum change. Thank you for the responses.
    Down
    Up
  • So any word on why the vintage products info page was axed??
    Down
    Up
  • Hello. Hope to get some opinions. I apologize upfront for my ignorance in your arena. I have two options to power a pair of sda srs 1.2. Nad 2600a bridged on each speaker or a MC7106. Would also like advice on what would be a good center channel for these. Thx in advance for advice and opinions. Vern
    Hello Vern,
    Welcome to Polk's forum. I'm afraid that when a two channel amplifier is placed in a bridged mode it is no longer compatible with a common ground speaker connection. You could use the amplifiers in a non-bridged two channel mode with no problem. If your second amplifier is a McIntosh MC7106 then I would imagine using two of those six channels would work fine. This is assuming the amp is compatible with a common ground speaker system (check with McIntosh to be sure).
    Regards, Ken
  • Thx Ken. I have the different cables that go in between the speakers one says for common ground and the other for not. I'm really unsure but my reading tells me I can bridge if I use the correct cable in between. Thx. Vern
    Hi Vern,
    You are correct, with the non-common ground cable you can use bridged amplifier.
    Cheers, Ken
  • NightfallNightfall Posts: 8,483
    I think you're talking about AI-1 or Dreadnaught? You have one of those?
    afterburnt wrote: »
    Village Idiot of Club Polk
  • pitdogg2pitdogg2 Posts: 14,687
    most bridged amps do not like a 4ohm load beware.....A1, dreadnaught or not..even though the 1.2 is 6 ohm rated I thinking it will and does go down to 4ohm and below...
  • I do have the AI-1 cable. So I should stay away from bridging my amps with these speakers?
  • In the distant past I have bridged my adcom 555II amps using the AI=1 with the 3.1TL's. Did not have any issues but also did not determine any discernible difference. maybe a little more clarity at very low levels. So I went back to the same ol, same ol. Held on to the AI-1 just in case I may want to do it again in the future.
    Polk 3.1TL (Gimpods boards, Sonicaps, Mills Res., Dynamat, Sonic Barrier, Hurricane Nuts, Cabinet sealing, Glue of magnets,Cardas Binding Post upgrades) - to be relegated to my daughters system eventually as I permit or am ready to part with.
    Polk CS350 Center
    Polk FX500 Surround
    Definitive Powerfield Subwoofer
    B&W 803D2
    Krell Showcase Processor
    Krell KAV 3250 Amp
    Adcom 555II Amp
    Adcom 555II Amp
    Musical Fidelity A3CD
    Sony PS4300 Turntable
    Rotel RQ970BX Phono Preamp
    Adcom Ace-515 Line Conditioner
    Richard Grays Power Company Line Conditioner (2)
    Hitachi 60" Ultravision TV
    Oppo BDP-103 Blue Ray
Howdy, Stranger!
