TV Calibration
Willow
Willow Posts: 11,296
edited November 2015 in Electronics
How often do you or have you calibrated your tv? Last time I did our plasma was about 8 yrs ago. Should this be done every so often? or should a one time calibration work? I don't see anything wrong with our set but perhaps it's because our eyes have slowly been watching the colors fade (for lack of a better word).
  • BlueFox
    BlueFox Posts: 15,250
    M TV was calbrated based on the existing gear (Blueray player, AVR, and cables) at that time. Over the years I have upgraded the Oppo, spliced a Shunata power cord into the TV, upgraded the power cables on the Oppo, and added a Triton for the gear, and a Hydra for the TV. Each one of these has changed the picture, so I should get it recalibrated, but haven't yet. It still looks really good, but I am sure it is out of calibration spec.
  • Willow
    I get you, I've added a new HDMI avr, a new BRP, new HDMI cables, not sure if any of those have affected it. I'm sure it won't hurt to pop in my calibration DVD, actually I don't have the BR version....hmmm
  • cstmar01
    cstmar01 Posts: 4,424
    If you are doing the disc I would say you would want to do it when you change out items. However if you did it based upon a professional calibration within the TV settings I wouldn't figure you need to update unless the life of the TV is starting to go and the color fade is just due to time left on the life.
  • steveinaz
    steveinaz Posts: 19,546
    I use the DVE bluray method, and have always been very pleased with the results. I did check it a few months ago, and my Panny was still dead on.
    If the colors are appearing dull, it might be because Plasma's on average lose their brightness over time. I believe it was something like 10 years old and they are at half brightness......generally speaking. You can try turning up the brightness in the settings and see if that helps.
  • Willow
    I'm not saying it looks bad. Just wondering if most people do it every couple of years.
    Professionally....no, with a disk, yeah. Even though I do it with a disk every few years, it only makes slight improvements. Those improvements get smaller as your set gets older and loses brightness. At some point, it won't matter at all I guess is what I'm trying to say.
