upgrade power cable for my SVS?
danger boy
danger boy Posts: 15,722
Hey,
any of you guys replace the power cord on your sub (Svs, or any other brand) with a new more heavy duty one? If so.. did you notice any output difference?
I'm thinking of replacing my sub power cable on the svs with one from Signal Cable. What do you all think? Worth it or not?
PolkFest 2012, who's going>?
Post edited by danger boy on
  • dorokusai
    dorokusai Posts: 25,640
    edited September 2004
    I upgraded mine to the SCMP before I even got the subwoofer. I upgrade my AC cords right out of the box. I did A/B's a long time ago, and don't even worry about it anymore as it's on less thing to worry about now. I think they are always a benefit and aesthetically they don't look like woman cords anymore. ;)
  • Early B.
    Early B. Posts: 7,900
    YES, upgrade the power cord and you'll hear a distinct difference. I just upgraded the cord on my Hsu STF-2 and the bass is even better -- stronger and more detailed. As Doro mentioned, I typically change out power cords at the time of purchase for all of my gear. I also have a few DIYers that work just as well as brand name power cords I've purchased.
    "God grooves with tubes."
  • polkatese
    polkatese Posts: 6,767
    agreed with Doro too, replacing stock cable with Signal Cable pc do wonder to my system...
    I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie.
  • danger boy
    which power cord do i order from Frank? the Svs seems to have a different configuration than most other prong type plugs.
    two plug blades instead of three blades
  • polkatese
    Signal Cable Magic Power, it sounded like SVS has one without the ground prong - give Frank a call, he will be able to custom made SCMP for you, with no grounding. Or you can get a regular SCMP and get a cheater plug from RS. I am assuming the two blades prong is on the AC outlet side.
  • dorokusai
    It doesn't matter about the missing ground pin, it will be the same termination. I have a missing ground pin on my AVR, and use a SC powercord on it just fine.
  • squish
    squish Posts: 34
    No really now... A power cord makes a difference to how a speaker can sound??? You guys are just too much... Why would an electrical cable change the sound.
    I have the cheapest extention cords, one with one three possible outlets, and i have them daisy chained so that i can get power to avr/tv/dvd/sub/dvr
    Now do you think i really would hear a difference if i used a $50 power strip?
    Equipment:
    Receiver: Onkyo TX-SR601
    Fronts: Polk RTi10's
    Center: Polk Csi40
    Rear: noname
    Subwoofer: SVS 20-39 PCi One day
    DVD: looking for better one
  • Early B.
    Yeah, I doubted it, too, until I tried it. I don't know why it works (and many "experts" don't know either), I just know that it does. Try it and let your ears be the judge. If it doesn't work, return it for a full refund.
  • dorokusai
    Why don't you sign up for the Polk Demo Program and decide for yourself. Good or bad, I don't care, that's for you to find out.
    Un-Official Polk Cable Demo Program
  • Loud & Clear
    Loud & Clear Posts: 1,538
    I'm thinking long and hard about installing a lightning rod into the sub, and then maybe upgrading all of the power lines in the area. But seriously, I'm not interested in upgrading my sub's (SVS) power cable. I think the cord they send is sufficient.
    Two Channel Setup:
    Speakers: Wharfedale Opus 2-3
    Integrated Amp: Krell S-300i
    DAC: Arcam irDac
    Source: iMac
    Remote Control: iPad Mini
    3.2 Home Theater Setup:
    Fronts: Klipsch RP-160M
    Center: Klipsch RP-160M
    Subwoofer: SVS PB12NSD (X 2)
    AVR: Yamaha Aventage RX-A2030
    Blu Ray: Sony BDP-S790
    TV Source: DirecTV Genie
  • EricH
    EricH Posts: 140
    But seriously, I'm not interested in upgrading my sub's (SVS) power cable. I think the cord they send is sufficient. [/B][/QUOTE]
    I totally agree. The power cable on my PB2+ is just like everything else on the sub, top notch. From internals and drivers, down to switches, control knobs, power cable etc.
