How "Polked" are you?
Cs400
(2) Cs350
Rm302
Ls50
Ab805
Ab855
(2) Ab705
(4) Ab755
65rt
Sc65
(2) 80fx ls
Several subs
Sda 2btl
Sda 4.1tl
Sda srs 3.1
T10?
M3
(2) m5
Almost an equal number of ADS
Mikey081057 wrote: »HT:
LSIM 705's
LSIM 703's
LSIM 702 F/X's
LSIM 706
dual MP2K subs
2c
Fully modded SDA SRS 2.3's
Monitor 5B's
LSi 9's with Fortress Mod
BR
Polk SB 9600 BT
Outdoor
Atrium 8 SDI's
How do you like the Atrium 8 SDI's? I just got a pair and really like them.
I liked them so much I bought a second pair... Sold the old ones with the old house, and put a pair here in my FL home... The bass is somewhat extended but that is not a bad thing for outdoors.
My New Year's resolution is 3840 × 2160
Garage | Polk Monitor 5B's
Closet Yamaha M80 | 2 Polk MP3K subs| Yaqin MC100B with Shuguang Treasures KT 88's & CV181Z's | Tesla E83CC's | Marantz 2252B | Marantz 2385 |Polk SDA SRS 2.3 | LSiM 705's | -
2.3TL fully modded
4.1TL
RTA 12C modded
LSiM 704C stock"Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer -
SDA 2B
SDA 1C
RT 15I
RT 55I
R20
Monitor 5BMcCormack DNA-1 Amp, Parasound Halo P5 Pre Amp, Denon DVD 2900 CD player, Adcom GDA 700 DAC, VPI Traveler TT with Denon 103R cartridge, Lounge Audio MKiii phono pre and Copla SUT, Polk SDA SRS 3.1 TL speakers, Tributaries series 8 IC's and speaker cable. -
Check my sig plus an old 8" powered Polk sub - not up to the "sig's" performance level.Samsung 60" UN60ES6100 LED Outlaw Audio 976 Pre/Pro Samsung BDP, Amazon Firestick, Phillips CD Changer Canare 14 ga - LCR tweeters inside*; Ctr Ch outside BJC 10 ga - LCR mids, inside* & out 8 ga Powerline: LR woofers, inside* & out *soldered LR: Tri-amped RTi A7 w/Rotels. Woofers - 980BX; Tweets & “Plugged*” Mids - 981, connected w/MP Premiere ICs Ctr Ch: Rotel RB981 -> Bi-amped CSi A6 Surrounds: Premiere ICs ->Rotel 981 -> AR 12 ga -> RTi A3. 5 Subs: Sunfire True SW Signature -> LFE & Ctr Ch; 4 Audio Pro Evidence @ the “Corners”. Power Conditioning & Distribution: 4 dedicated 20A feeds; APC H15; 5 Furman Miniport 20s *Xschop's handy work
HT
Monitor 12 Series 2 (fronts/ 2 ch)
Monitor 7 Series 2 (center)
Monitor 5 Series 2 (rears)
Monitor 5B (rear surrounds)
BR
Monitor 10B (fronts/ 2 ch)
Others in use:
Monitor 5jr+ (w/ SL2000)
RT25
CS245- SDA 2B (1989, Oak Tops, 194s, Spikes)
- Monitor 7B (1982 Peerless, Sonicaps, Mills, Dynamated, JB Welded, Binding Posts)
- SVS SB12-NSD (2 in Flat Black)
- SVS SB 3000 (Gloss Black)
- Pioneer SC-1222K AVR
- Marantz MM 7055 (5 Ch Amp)
- Pioneer PD-D6 SACD Player
- Marantz NR1403 AVR
- Sony UBP-X800M2 (4k Blu-ray)
- Sony UBP-X1100ES (4K Blu-ray)
- Adcom GFA 555
- Monitor 5 (194s, Side Surrounds)
- Monitor 5Jr+ (194s)
- LG OLED65CXPUA (4K OLED TV)
- LG 55UN7300PUF (4K HD TV)
- RT35i (Cherry)
- CS400 (Center)
- CS350 (Center)
- F/Xi A4 (Rear Surrounds)
- RT25 (Rear Surrounds)
- Audioquest Cables
" But boy do I remember the strain of her refrain " LG -
I'm not very "Polked" at all, but that doesn't mean that I don't want to be. When I was in my early teens, and in my late teens, there were two pairs of speakers I always wanted. In my early teens, it was the Polk SDA and/or Monitor series. In my late teens, it was the NHT 3.3 and/or 2.9.
Well, 11 years after they debuted, I finally got myself a pair of NHT 2.9's at a great deal. They were/are everything I read about all those years in the stereo mags, and then some. The only reason I'm not using them now is because I just can't get them to cooperate with our current apartment. I just can't get the spacing and positioning right to get them to sing, which brings me to Polk...
My very first Polk's are a pair of PSW505 subs that are sitting in our daughters bedroom with a kitty bed on them. The cats love sleeping in that bed, and it's a good way to protect the tops of the subs. I bought these after selling my last SVS sub.
The PSW505's were run with a pair of AV123 X-Statik speakers that I now use as surrounds. They're great speakers but lack the lowest octave of bass. I also have the matching X-Voce center channel that I also still use. It's the best sounding CC that I have heard at anything below $4k.
I stopped using the Polk subs for music when I got a pair of Genesis Physics II's that I restored and completely rebuilt the crossovers in. I used the Polk subs as speaker stands for the Genesis speakers and only used them with movies. The Genesis speakers actually put out better, lower bass than the PSW505's when it comes to music. They just can't move enough air though for movies.
I stopped using the subs altogether once I got the NHT 2.9's as they extended deeper than the Polk subs do. There's no need for subs that extend down to only 24Hz when you have a pair of towers that extend down to 18Hz.
Now I'm running a pair of RTi12's and have the NHT 2.9's stored at my brother's house for the reasons explained above. The RTi12's sound just about as good as the NHT's surprisingly enough, but with even better quality bass, and with even more usable output down around 18Hz.
So that's my list for now...- PSW505 x 2
- RTi12 x 2
I will eventually grow that list out, but with some vintage Polk's such as the SDA and Monitor series. I've never heard a pair or even seen a pair in person, but I know I'll like them regardless. It's just a matter of finding a pair in good shape at a decent price. -
12 Polk speakers in the house and two at work. Polk does make a great product from their low end to the top. For subs I have HSU which for the cost are better than the Polk.
I had a part time job in 1989 at DOW/Tweeter and loved the Polk line. They were the go to speaker to push a deal. Full time sales guys got pissed at me because I pushed Polk and Sony, I had higher sales in the 3 nights I covered than the 5 day a week guys.When I was a kid my parents told me to turn it down. Now I'm an adult and my kids tell me to turn it down.
Working Warehouse; Yamaha A-S301, Sony DVP-NS3100ES for disc Plok TSX550T SVS PB2000 Mini tower PC with 400GB of music -
@Chops, I'm curious as to why you went with a pair of Polk RTi12's vs a pair of LSi15's for two channel music?
The simple answer is that my brother already had the Polk's and we swapped speakers.
He's now running the NHT's in his system. He's got the better room layout for them than I do. He also didn't like something in the midrange with the Polk's. I didn't either when they were in his system. However, after bringing them over here and running them on my system, the midrange sounds just fine. Very neutral and natural.
It might have had something to do with the dual Emotiva XPA2 Gen 2 amps he was running at the time. Those amps are great for HT use, but not for 2-ch music use. He now runs a Marsh A-200s which sounds tons better on those old NHT's of mine.
I saw a pair of LSi25's in the FS section and was getting excited due to the greatly reduced price. I was about to contact the seller until I noticed a few posts towards the end where they had already sold.
And if they ever showed up on the market at a good price, I would certainly entertain a pair of Polk SRT's! Definitely the old SDA also. -
Bright speakers like the RTi's and Emotiva XPA amps just don't get along well. Most people 'round here recommend Parasound or B&K cause they are a mellower amps for the RTi series. I even went that route with my A7s...nice pairing. Amps do matter as I've learned.
Very true. Before I ordered my Khartago amp I was running a little Class A 25 watt Monarchy Audio SM-70 Pro on the NHT's. That little amp did very well and sounded much bigger than 25 watts have any right sounding, especially on power hungry speakers like the 2.9's. Very "tubey" sounding.
Before...
After...
SL2000 Monitor 5's
Peerless RTA-12B, Monitor 5, and Monitor 4's
Monitor 4's with the triangle looking plastic fronted tweeter
My dad has the first 2.3's with SL2000 that he bought in Germany during Desert Stormafterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
Village Idiot of Club Polk -
I did not realize the numbers but...
2.3TL's
1C's (studio) X2
Monitor 10's X2
Monitor 7's X2
SDA 1B's all the way in MN looking for cows!
RTA 15TL's Geoff holding onto them for me in SeaTac!
CS 1000
Ultra Focus 8000's X2 (Friends and Family splurge)
SDA 2B's
LSI 9's
Don't tell the wife, but there is a set of 2B's in the hood that I am trying to pick up. Why?, I don't know. Lucky 13 maybe?
Nathan
Home Rig
SDA 2.3TL's front and center
Polk 1000p Center
Pioneer Elite SC35 Receiver (Pre/Surround
Sunfire Cinema Grand 5X200-Back in the mix.
OPPO BDP-93
Squeezebox
Stepped up to name brand Speaker Cables and interconnects!
Monitor 4, 5, 7, 10's, SDA 1B's, 2B's, 2.3TL's, RTA 15TL's all in storage waiting for me.
Sales Rating #1!! -
My first home theater system consisted of:
Fronts: Polk Audio Monitor 50
Center: Polk Audio CSiA4
Surrounds: Polk Audio RTi4
Sub: Polk Audio PSW 505
So, my first home theater system was definitely "Polked". (Pair those speakers with my Yamaha RX-V663, and, yes, my ears did bleed when I cranked it. )
In my present system, I have Polk Audio RTi6's as my surrounds.
Paradigm 11seMkIII mains, w/ Zu Audio jumpers
Paradigm CC 450 center, w/ Zu Audio jumpers
Polk Audio RTi6 surrounds
Paradigm SE sub
Sony BDP S5100 blu-ray player
Panasonic 50" plasma
Yamaha RX A1000 receiver
Parasound HCA 1205A amp
Audioquest Evergreen IC's -
feeling a little smaller after reading this thread:
RT7's
Monitor 7's
LSiM 703's
LSiM 706c
Gave away the CS10
Sold the S series...
monitor 55t x 2
monitor 65t x 2
monitor 75t x 2
tsi200 x 2
csi5 x 1
You wouldn't have been able to snag the LSi25's even if you had___ contacted the polkie selling them. You need to have 100 posts or more here to have the privilege to buy or sell in the FS section here. Contributing to this forum helps us all , stick around ,get your read on , share your knowledge of audio with others,learn from others here, before you know it, you'll have 100 posts and counting. -
R15 pair
R30 pair
Csi3
Rti10 pair
Csi5
Fx500 pair
Rti4 2 pairs
Lsim705 pair
Lsim706c
Lol I have accumulated these over the last ten years.lsim705,lsim706c,lsif/x(4)+mc80(atmos)
rti6,csi5,fxi5 -
R20 - Pair
Monitor 30 - Pair
CS175i - Center
PSW350 - Sub
Monitor 7II - Pair
M3 ii - Pair2 Channel "Polk" Room:
Marantz PM8004 Integrated
Marantz SA8004 SACD Player
WiiM Mini
Polk 7B with RDO198s -
(presently own)
SDA CRS (pair)
RT55i (pair)
RT35i (pair)
RTi38 (pair)
CS400i (center)
PSW450 (sub pair)
PSW111 (sub)
(recently sold)
RT800i (pair)
Monitor 5Jr+ Series 2 (pair)Main System:
Proton AA-1150 ~ Yamaha C-4 ~ Furman Elite-15 DMi ~ Sennheiser HD600 ~ Monitor Audio Silver RS8 & FB210 ~ Martin Logan Dynamo ~ Teac R-919X ~ Marantz CD5003 ~ Squeezebox Classic ~ Music Hall dac25.2 ~ Dual 1229/Acutex M312 III STR ~ Music Hall mmf-5.1/Goldring 1012GX ~ Music Hall Cruise Control 2.0
Home Theater:
Vizio V585-H11 ~ Yamaha RX-V800 ~ Furman Elite-15 DMi ~ Marantz DV6001 ~ EPI M90 ~ Polk Audio RT35i ~ CS400i ~ (2) Polk Audio PSW450 -
I know people will say the speakers don't sound good used together however I love them.
HT/ 2x Paradigm 90p towers
2x Polk RT10s
2x Polk TSI200s for surrounds
Polk csi100 center
Velodyne cht12
Some harman kardon 8inch sub that's meh.
Bedroom I have a pair of Polk Monitor 5s with the sl2000s
Marantz pm305
Marantz EQ10
Pioneer Pl510
Got some RTA11tls I need to fix which will take the paradigms place.
Hope to own some SDAs one day...Just a dude doing dude-ly things
"Audiophiles are the male equivalent of cat ladies." - Audiokarma Member -
wow...answering honestly makes me realize I need a support group for hoarders and to clean out the closet...
RT5000p
CS400
RT8
LSi25
LSi9 (2 pairs modded)
LSi7 (sonocapped)
LSiC (4)
LSiFX (2)
LSiM 705 cherry
LSiM 703 (1 pr cherry 1 pr mahogany
LSiM 706c (1 cherry 1 mahogany)
rt 500 fx
RTA 15TL (modded)
SDA 2.3 (modded)
I guess they say admitting you have a problem is the first step... -
I got polked in the eyes
SDA-SRS 3.1TL's
SDA-1C
CS-1000p
CS-400
Monitor 5jr's
RT-35i's
RT-55's
PSW-200's (2)
PSW-150's (2)
AMR5
AMR-SW
- Adcom GFA 555
- RT35i (Cherry)
- CS400 (Center)
- CS350 (Center)
- Audioquest Cables
- Adcom GFA 555
- RT35i (Cherry)
- CS400 (Center)
- CS350 (Center)
- Audioquest Cables
Very nicely staged. Good photography. Looks like an advertisement. Nice job! from one Polk hoarder (collector-aficianado) to another. Cheers.
ken brydson wrote: »
If this is sick, I don't wanna be well!TCK do you mind if I start calling you Noah
They all have their place in the arc, 2 X 2aprazer402 wrote: »Very nicely staged. Good photography. Looks like an advertisement. Nice job! from one Polk hoarder (collector-aficianado) to another. Cheers.
Thanks! I thought it looked like a Polk dealership from the 80s too- SDA 2B (1989, Oak Tops, 194s, Spikes)
- Adcom GFA 555
- RT35i (Cherry)
- CS400 (Center)
- CS350 (Center)
- Audioquest Cables
Question #1 - is that how you have them set up on a day to day? It must be hard to watch tv.
Question #2 - How long does it take you to vacuum?Where’s the KABOOM?!?! There’s supposed to be an Earth shattering KABOOM!!!
