RT3000P volume control noisey...then Sub amp went out
shadowofnight
Purchased an RT3000P 4 piece speaker set new a good while back ( 5 year warranty way over ) ....one of the subs volume control became gritty ...while moving left to right sub went silent :eek:
Popped out amp and its not a fuse issue....Would like to send the amp and volume switch in to Polk to get this back to factory functioning . Help me Mr Wizard Kenneth
Will polk even look at a nonfunctioning sub amp/volume control out of warranty ? Thanks in advance for your time
P.S. Speakers functioning fine ( Ohm out fine ...electrically fine...physically fine )
The first rule of Fight Club is you don't talk about Fight Club
Post edited by shadowofnight on
Hello,
Absolutely, no problem. Just send the amplifier and logo pod to Polk Audio, 2550 Britannia Blvd., Suite A, San Diego, CA. 92154. Please include a short note giving us your name, address and a daytime telephone number. They'll be happy to check it out for you.
Take care, Ken -
Thanks a bunch Ken
The first rule of Fight Club is you don't talk about Fight Club -
I have polk rt3000p and one subwoofer volume control stopped working. Its always on maximum. What can be done to fix it?
Try to clean out the volume pot with some contact cleaner. If that does not work, see if Polk still has those parts in stock.2.2 Office Setup | LG 29UB55 21:9 UltraWide | HP Probook 630 G8 | Dell Latitude | Cabasse Stream Amp 100 | Boston Acoustics VS 240 | AUDIORAX Desk Stands | Sub 1 - Mirage Omni S8 | Sub 2 - Mirage Omni S8
It's not very common but they do go bad occasionally. I think you can still buy the volume control potentiometers from Polk. At least you could a couple years ago.
I had a CS1000p with a bad one that I replaced. It uses the same part # as the RT3000p subs do. I bought three of them to have as spares and still have two left. Send me a PM if Polk is out of them or you need one. I will give you a good deal. It includes the cable, connector and everything so it is basically plug & play. Real easy to swap out.
NOS never used parts:
