RT3000P volume control noisey...then Sub amp went out
shadowofnight
shadowofnight Posts: 2,735
edited February 2008 in Troubleshooting
Purchased an RT3000P 4 piece speaker set new a good while back ( 5 year warranty way over ) ....one of the subs volume control became gritty ...while moving left to right sub went silent :eek:
Popped out amp and its not a fuse issue....Would like to send the amp and volume switch in to Polk to get this back to factory functioning . Help me Mr Wizard Kenneth :) Will polk even look at a nonfunctioning sub amp/volume control out of warranty ? Thanks in advance for your time
P.S. Speakers functioning fine ( Ohm out fine ...electrically fine...physically fine )
The first rule of Fight Club is you don't talk about Fight Club
Post edited by shadowofnight on
  • [Deleted User]
    [Deleted User] Posts: 7,658
    Hello,
    Absolutely, no problem. Just send the amplifier and logo pod to Polk Audio, 2550 Britannia Blvd., Suite A, San Diego, CA. 92154. Please include a short note giving us your name, address and a daytime telephone number. They'll be happy to check it out for you.
    Take care, Ken
  • shadowofnight
    Thanks a bunch Ken :D
  • I have polk rt3000p and one subwoofer volume control stopped working. Its always on maximum. What can be done to fix it?
  • WLDock
    WLDock Posts: 3,073
    Try to clean out the volume pot with some contact cleaner. If that does not work, see if Polk still has those parts in stock.
    2.2 Office Setup | LG 29UB55 21:9 UltraWide | HP Probook 630 G8 | Dell Latitude | Cabasse Stream Amp 100 | Boston Acoustics VS 240 | AUDIORAX Desk Stands | Mirage Omni S8 sub1 | Mirage Omni S8 Sub2
  • Gatecrasher
    Gatecrasher Posts: 1,550
    ymishtal wrote: »
    It's not very common but they do go bad occasionally. I think you can still buy the volume control potentiometers from Polk. At least you could a couple years ago.
    I had a CS1000p with a bad one that I replaced. It uses the same part # as the RT3000p subs do. I bought three of them to have as spares and still have two left. Send me a PM if Polk is out of them or you need one. I will give you a good deal. It includes the cable, connector and everything so it is basically plug & play. Real easy to swap out.
    NOS never used parts:
