Monitor Series "Handbook".
HzTweaker
HzTweaker Posts: 1,034
Does anyone know if a PA Monitor Series Handbook exist? (Like the link attached)
http://vr3mods.com/uploads/SDA_Handbook_2011_Rev3.pdf
    F1nut Posts: 51,953
    It does not.
  • Nightfall
    Nightfall Posts: 10,083
    What information, exactly, are you looking for?
    afterburnt wrote: »
    Village Idiot of Club Polk
  • HzTweaker
    Nightfall wrote: »
    Bio information. Factory stats on all Monitor series in one "book"..ect..
  • Nightfall
    HzTweaker wrote: »
    Nightfall wrote: »
    You can find a lot of them here
    http://web.archive.org/web/20140628092311/http://www.polkaudio.com/vintage
    afterburnt wrote: »
  • Nightfall
    Example: Monitor 7
    http://web.archive.org/web/20140714025143/http://www.polkaudio.com/products/monitor7
    Tweeter
    Quantity 1
    Diameter 1" (2.54cm)
    Type Polk SL2500 dome tweeter
    Midrange
    Quantity 1
    Diameter 6 1/2" (16.51cm)
    Type drivers
    Subwoofer
    Quantity 1
    Diameter 10" (25.40cm)
    Type sub bass radiator
    Electrical
    Total Frequency Response 25Hz - 25kHz
    Upper -3dB Limit 23 kHz
    Lower -3dB Limit 40 Hz
    Nominal Impedance 8 ohms
    Efficiency 89 dB
    Recommended Amplifier Power 20-150 watts per channel
    Amplifier Specs
    Amplifier Type 0
    Dimensions
    Cabinet Dimensions
    Height 24" (60.96cm)
    Width 13" (33.02cm)
    Depth 10" (25.40cm)
    Shipping
    Total Shipping Weight 33.00 pounds
    afterburnt wrote: »
  • HzTweaker
    Thanks!
  • skrol
    skrol Posts: 3,460
    A while back I was working on a vintage Polk document. Never finished it but I attached what I have.
    Stan
    Main 2ch:
    HT:
    Other stuff:
    mhardy6647 Posts: 35,200
    edited October 2015
    Nice! :- ) Thanks for sharing that draft, sir.
    Like many smaller manufacturers, Polk's product specs (in the broadest sense) were rather a moving target in the early days.
    In fairness to Polk (and everyone else that made many run-time changes to their products) the product literature often had a disclaimer that said something to the effect of "specifications subject to change without notice".
  • HzTweaker
    skrol wrote: »
    Thanks, I currently cant view it because I'm using a work computer :neutral: I'll check it out soon though.
