Break in: what do you folks think?
I read this somewhere and think it's a bunch of hooey. What says yooz?
"Many people leave the gear on all day, for weeks even. I am very much against this. What do we mean when we say a part like a capacitor must "break in"? It's just wound metal impregnated with some kind of oil usually, what "breaks" in. Obviously the metal. From having some blacksmith knowledge, I know metal breaks in by tempering, but it can be tempered 2 ways. If it is hot all the time and then suddenly cold it makes it hard and brittle. If you get it hot then cold then hot then cold etc... repeatedly (in other words a middle range) it tempers it softer. If you play it no stop all you have is heat, and then suddenly it gets cold. I have heard too many people who do this complain that their systems sound strident and never "broke in" properly and I believe this is why. What's more it seems to lengthen the time required to break it in once they start cycling it properly. All gear is different but most electronics seem to take about 300 to 400 hours to fully break in"
«13
  • motorhead43026
    motorhead43026 Posts: 4,009
    edited October 2015
    There is not enough heat generated in a piece of consumer SS electronic equipment to temper any metal.
    – Kevin Alfred Strom
  • Except maybe an older Onkyo AVR.
  • BlueFox
    BlueFox Posts: 15,251
    "From having some blacksmith knowledge..."
    LOL.
    pitdogg2 Posts: 27,038
    still no those just "tempered" the HDMI inputs and outputs......into TOAST....:)
  • voltz
    voltz Posts: 5,384
    In another thread Ken gave the best answer I ever heard, to lazy to dig it up and find it but maybe he will re-post it.
    When I was burning in my Monitor 10 crossover that Dave (westmassguy) rebuilt for me, I heard the biggest difference in the Mid's to upper end. And was nice to hear the sound evolve as I would listen to them every Sunday after 70+ more hours of burn in.
  • Nightfall
    Nightfall Posts: 10,084
    Yawn
    afterburnt wrote: »
    Village Idiot of Club Polk
  • cfrizz
    cfrizz Posts: 13,415
    These are simply people with OCD, cause they just don't bother taking their medication which would let them put the system together, then throw on some music or a movie and enjoy it.
    Are there differences? Of course, I noticed a real big difference between a 120wpc receiver driving my speakers and a brand new 205wpc Parasound 1500A amp driving my speakers.
    Was the amp breaking in during this time? I have no idea, I was too busy going through all of my cd's finally hearing all the details that I was missing when I just used my receiver.
  • steveinaz
    steveinaz Posts: 19,545
    There many electrical components that "break-in" due to heating and cooling cycles. This isn't "voo-doo" it's well known and documented. Now, wether or not an audible difference can be noted, may be arguable.
    tonyb Posts: 33,072
    My take on break-in.....don't frickin' worry about it. If it happens and you do hear a difference, cool....if you don't, cool too. Just listen to your music and don't fret over it.
  • soundfreak1
    soundfreak1 Posts: 3,414
    Pretty much anyone with ears and experience with vintage audio gear of new caps in thier xovers ( including myself) have documented bteak in and warm up changes in the sound thier system produces! Im not a blacksmith, metalergist, or eletronics engineer so i cant explain the phenomena in detail but i have ears and have heard and can hear the difference in the sound all of my vintage systems sound after warm up and the sound my speakers make after rcap and breaking them in. If yours dont or you cant hear it i dont know what to tell you except listen closer.
    Main Rig:
    Nakamichi EC100 Active xover
    MIT exp 1 ic's
    Perreaux SA33 class A preamp
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    MIT exps2 speaker cable
  • drumminman
    drumminman Posts: 3,396
    Burn in is real, at least in components I've had over the years. Nothing to fret over though - just play the rig. I've often had an "aha!" moment when I notice a sudden increase in sq after some hours of use.
  • Break in IS important;
    F1nut Posts: 51,751
    xcapri79 wrote: »
    Note, speaking for myself and only myself, my perception of sound is mostly due to the many factors of psychoacoustic phenomena and is greatly influenced by expectation bias.
    Corrected because you shouldn't speak for everyone else.
  • afterburnt
    afterburnt Posts: 7,892
    I have no doubt about break in it,s the blacksmith carp that I think is bs
    F1nut Posts: 51,751
    There you go again, speaking for others.
  • soundfreak1
    Lmao
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
  • afterburnt
    So it's not a myth?
  • mikeyb128
    mikeyb128 Posts: 2,885
    here we go....
    2 channel:
    Theater:
    edited October 2015
    mikeyb128 wrote: »
    here we go....
    I'm ready. Just back from a conference and fired up the "tubes". Glad to see everything is back to normal here. lol
    I did give those tubes 30 minutes or more before I put on the music though!
    Who are the PsychoAcoustics, you ask?
    https://www.youtube.com/watch?v=QNGb0okOPfo
    Post edited by cnh on
  • motorhead43026
    edited October 2015
    Break-in and get caught, better plan your breakout.
  • all equipment is the same. If it is quality built, there is no break-in.
    nooshinjohn Posts: 25,916
    What do I think? The OP and Xcapri are showing their trolling techniques are just as effective as ever.
    txcoastal1 Posts: 13,512
    To my ears ClassA and tube gear along with speakers with complicated crossover circuits definitely require a breakin/or warm up.
    Keep in mind that results may not be positive.
  • afterburnt
    What is with this trolling garbage? Asking a question is trolling?
  • Nightfall
    afterburnt wrote: »
    You didn't start this thread because you knew it was going to garner attention and controversy? Truly? If you were really just searching for info there are a ton of threads on the subject you could have read, all of which end the same way this one is.
    afterburnt wrote: »
  • afterburnt
    edited October 2015
    No I did not. The excerpt that I posted was the first time that I had seen such a theory expressed so I ask for you guys thoughts. I don't post questions about cables even if I have a legitimate question because I have seen how those question usually end up. Now I know not to ask about break in either. At any rate I don't see why anyone here should have to self censor their questions just because some people are going to freak out about them. I would hope that people could ask a question without fear of kicking a hornets nest.
  • Nightfall
    afterburnt wrote: »
    No I did not. The excerpt that I posted was the first time that I had seen such a theory expressed, so I asked for your guys thoughts.
    Fair enough.
    afterburnt wrote: »
  • besides, a little trepanning is good for the forum. :#
  • afterburnt
    Nightfall wrote: »
    afterburnt wrote: »
    Fair enough.
    Afterburnt did not write that
  • steveinaz
    As I said, the cooling and heating up of some electrical components changes their properties. AGAIN this isn't voo-doo, look it up yourself on the net.
