Atrium 4 or 5 for new covered porch? Best sound for open environment?
apc
apc Posts: 779
edited September 2015 in Speakers
Open on 3 sides, approx 8" ceiling with fan and 4 brick columns. Concrete floor. Ceiling will be hardwood flooring with crown moulding.
Husband, Father, Son, Brother, Friend.
Sign in to vote!
This is a public poll: others will see what you voted for.
  • Atrium 5
    I prefer the 8's but could live with the 5's.
    Garage | Polk Monitor 5B's
  • vmaxer
    vmaxer Posts: 5,121
    Me too.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
    Take a look at the Def Tech aw6500 too. You can find them on Ebay all day for under 2 bones each.
  • rooftop59
    rooftop59 Posts: 8,120
    Sorry I didn't vote because I haven't heard either. But I have just a very small covered entry into the house (maybe 5-6 feet deep and closed in on the sides) and I just use an old pair of rt25is. They sound great, they have held up for close to a year now with no issues, and best thing is I got them on ebay for something like $60 shipped. So if/when the elements do get to them, I will just look for something else used. If your patio is covered and you can place them in a couple feet on each side, they might be fine for years. And bookies will often sound better than the outdoor speakers. Just a thought...
    Game Room 5.1.4:
    Bedroom 2.1
  • Bass sucks in covered porches so get the biggest you can find. Sun damage is what will get them so try to keep them high and out of direct sunlight if at all possible. As previously mentioned you can probably get away with more traditional speakers if you do this. I've had a couple sets go bad and it was always the sun that killed them. Maybe grills nowadays are better but the speaker surrounds couldn't take direct sunlight on the previous sets I had.
