Atrium 4 or 5 for new covered porch? Best sound for open environment?
Open on 3 sides, approx 8" ceiling with fan and 4 brick columns. Concrete floor. Ceiling will be hardwood flooring with crown moulding.
Husband, Father, Son, Brother, Friend.
Atrium 4 or 5 for new covered porch? Best sound for open environment? 5 votes
Atrium 5I prefer the 8's but could live with the 5's.My New Year's resolution is 3840 × 2160
Garage | Polk Monitor 5B's
Closet Yamaha M80 | 2 Polk MP3K subs| Yaqin MC100B with Shuguang Treasures KT 88's & CV181Z's | Tesla E83CC's | Marantz 2252B | Marantz 2385 |Polk SDA SRS 2.3 | LSiM 705's | -
Mikey081057 wrote: »I prefer the 8's but could live with the 5's.
Me too.Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
Take a look at the Def Tech aw6500 too. You can find them on Ebay all day for under 2 bones each.HT SYSTEM-
lsi 9's -
Sorry I didn't vote because I haven't heard either. But I have just a very small covered entry into the house (maybe 5-6 feet deep and closed in on the sides) and I just use an old pair of rt25is. They sound great, they have held up for close to a year now with no issues, and best thing is I got them on ebay for something like $60 shipped. So if/when the elements do get to them, I will just look for something else used. If your patio is covered and you can place them in a couple feet on each side, they might be fine for years. And bookies will often sound better than the outdoor speakers. Just a thought...Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es; Squeezebox Touch with Bolder Power Supply
Bedroom 2.1Cambridge Azur 551r; Polk RT25i; ACI Titan Subwoofer -
Bass sucks in covered porches so get the biggest you can find. Sun damage is what will get them so try to keep them high and out of direct sunlight if at all possible. As previously mentioned you can probably get away with more traditional speakers if you do this. I've had a couple sets go bad and it was always the sun that killed them. Maybe grills nowadays are better but the speaker surrounds couldn't take direct sunlight on the previous sets I had.
