USB Small stand fans..??
Anyone have ones of these or know if they well without a lot of noise? Thinking of trying one out to cool down my tube amp. Thanks!
Computer room Hegeman 1 SpeakersM&K VX-80 subKenwood DP-7010Cambridge Audio CXC Transport Rega DACPrimaLuna Prologue Four AmpAric Audio Tube PreampGarage Jennings Research SquareCustom tube preampCrown XLS-1000Denon DCD-1500II Modded MSB Link DAC
  • starkiller
    starkiller Posts: 2,723
    nobody?
  • drumminman
    drumminman Posts: 3,396
    I have a couple of 5" computer/ audio cabinet cooling fans I can sell you. I used them to cool an amp until I had it looked at and modded. Each has an on-off-fan speed switch, ball bearing motor and can be mounted or simply set on a flat surface, and they plug into the wall on standard household current (no transformer). Very quiet too, and rated for a life of something like 30,000 hours. I used them for around 50 - 100 hours.
    I paid around like $25 each, but would let them go for $30 + shipping.
  • shawn474
    shawn474 Posts: 3,052
    I have one of these that I have plugged in to switch on with my amp to cool it down while in the cabinet. I have it pointing out of the cabinet as an exhaust to take the heat away from the cabinet. Works great and they have great customer service. It is also available in a USB version. I have never noticed the noise unless I am right beside the cabinet.
    coolerguys.com/840556096955.html
    Shawn
    AVR: Marantz SR-5011
    Center Channel: Polk LsiM706c
    Front: Polk LsiM703
    Rear: LSI fx
    Subwoofer: SVS 20-39pci
    DVD Player: Sony PS4
  • rooftop59
    rooftop59 Posts: 8,120
    Yep I have one from cooler guys as well, one of the cheap 12$ ones. I don't notice it, but in my jungle of a house it takes a lot of noise for me to notice...
    Game Room 5.1.4:
    Bedroom 2.1
  • +1 on the coolerguys... they have what you need. I would choose one from these guys as they wouldn't sell noisy fans.
    Garage | Polk Monitor 5B's
  • starkiller
    Hmm, I will need to mount the fan on the left side of the shelf to blow the air away from me as I am sitting about a foot away so it needs to be pretty quiet..see pic :)fv9w0tx0upax.jpg
  • WilliamM2
    WilliamM2 Posts: 4,808
    I don't think you will find a fan that can't be heard from a foot away. I just use quiet 12v computer fans, powered with a 5v adapter to make them even quieter. Can't hear them from about 4 feet away, and I sit 12 feet from them. But 1 foot I can still hear them easily.
  • nguyendot
    nguyendot Posts: 3,594
    Main Surround -
  • starkiller
    Nice, but then i would have to use a soldering iron i don't have much less the lack of any skill to use one with the peripheral neuropathy in my fingers :)
  • madmax
    madmax Posts: 12,434
    I suggest not allowing air from the fan to come into contact with the tubes. I had a tube crack when doing so.
    Vinyl, the final frontier...
  • starkiller
    Hmm, then how does one keep the heat at bay??
  • madmax
    starkiller wrote: »
    Keep heat from bothering the amp or keep the heat from bothering you?
  • Fan noises drive me nuts too. You could use a computer muffin fan with a thermal switch so it only runs above a certain temp, but short of using a water cooling system, there's gonna be noise.
    SDA SRS 2.3TL (for sale)
  • starkiller
    madmax wrote: »
    starkiller wrote: »
    From bothering me :)
  • starkiller
    Well, went a got a clip fan from the local thrift so will see what happens :)
