2 Channel Refinements
Mikey081057
Mikey081057 Posts: 7,127
edited September 2015 in 2 Channel Audio
Did a little moving stuff around between the HT and 2 channel system and now have this rig back in business.
Parasound P5
Parasound A21
Marantz SA 8004
Bluesound Node
Music Hall MM 5.1
MIT Shotgun S's
SDA SRS 2.3
AQ King Cobra balanced and rca interconnects.
Garage | Polk Monitor 5B's
  • oldrocker
    oldrocker Posts: 2,590
    Nice looking.
    Especially that big shiny silver faced monster in the middle.
    Working a "deal" on one of them myself.
  • oldrocker wrote: »
    Nice looking.
    They are special and getting hard to find at a reasonable price. Good Luck!!!
  • @Mikey081057,
    Looks very, very nice!
    Well done, and I bet it sounds great!
  • Joey_V
    Joey_V Posts: 8,603
    Looking good
  • Upstatemax
    Upstatemax Posts: 2,783
    Looks awesome!
    I'm seriously torn between a Marantz SA 8004/5 and an Oppo BDP 105...
    I think the Marnantz might be a bit more musical, but the Oppo brings A LOT of functionality to the table.
  • I think you have to weigh it this way:
    If you are ONLY going to listen to music, then the Marantz is the plan.
    If you are going to watch video as well then the 105 is the ticket.
    Either is a very good option that you won't regret.
  • Upstatemax
    Blu-Ray playback is a bit of a sticking point for me...
    I have several Blu-Ray concerts or albums that would be taken off of the table otherwise.
    On one hand, I want the best musicality, on the other, I want it to do everything.
    The two main reasons I'm leaning toward the Oppo: Blu-Ray playback and the ability to hook a monitor to it for said Blu-Rays and managing digital playback.
  • WagnerRC
    WagnerRC Posts: 2,209
    mikey have you had your 2385 serviced? man that looks like mint condition. I have mine here that I bought new. Thanks
  • Upstatemax
    DSkip wrote: »
    I need to get my ears on the UD-7007 and see how it stacks up since that is a more even playing field for the Oppo.
    Even if the UD-7007 sounds like Jesus and all the Angels singing, it will NEVER come into my home...
    I have had too many Marantz universal players fail on me to ever buy one again.
  • oldrocker
    oldrocker wrote: »
    Nice looking.
    Time will tell. The guy that owns it, has it sitting on a dresser in a 2nd bedroom, covered in dust, not even hooked up.
    But I have a plan, he's a bose fan and I have a set of 901's with the eq sitting in the original boxes with about 5 hrs on them. So he's wanting to do dome sort of trade. Heck he can have them straight up, but I'm not telling him that at this point..... B)
  • Upstatemax
    DSkip wrote: »
    Max, what all has failed you? I remember the 5005 thread. Were there others? Was there a common thread, like buying from the same place?
    I also had a Marantz DV-7600 that was nothing but problems. Even the repair shops could not figure it out.
    I will quote one; "I've seen some weird stuff, this thing is just not making any sense! There is something seriously wrong with it".
  • WagnerRC wrote: »
    The only problem mine had was lamps and a scratch volume pot.. Some LED's alittle deoxit gold did the trick.
    I would send it in to get it checked out if there was someone in SW FL who I could trust.
  • WagnerRC
    I have the same issue with the volume pot. deox only works so so for some reason. Congrats on a beautiful receiver. My wood case needs some work.
  • PSOVLSK
    PSOVLSK Posts: 5,399
    Nice looking setup. I know it sounds even better than it looks.
  • steveinaz
    steveinaz Posts: 19,546
    Very nice rig Mikey.
  • erniejade
    erniejade Posts: 6,321
    Nice setup! I like it!
  • I am hard pressed to imagine something that would give this much value in the 3 to 3.5K price range than the P5 A21 combination. I would like to hear everyone's thought/opinions/comments as I am sure to have drank the Parasound Kool aid at this point.
  • styx
    styx Posts: 37
    Nice setup.
    Styx
    Condo: HK-3490, HK Bridge II, HK BTA-10 Polk TSx500T's
  • motorhead43026
    motorhead43026 Posts: 4,029
    edited October 2015
    Parasound Kool-Aid is easy to drink, as it goes down easy. That is a great combo for the money, kool-aid or not.
    – Kevin Alfred Strom
  • ukcolin99
    ukcolin99 Posts: 286
    mikey looks very nice, do have a fan near the A21, Manual recommends 6" clearance above the unit-no heat issues?
  • Emlyn
    Emlyn Posts: 4,812
    edited October 2015
    The chassis on the A21 is oversized for its purpose because it is also used for the A51 and A31. Heat is dissipated from the large heat sinks on the sides rather than through the vented top. Mike's setup looks fine because the rack is open and there is some clearance at the top. The A21 runs warm rather than hot.
  • Mikey081057
    Runs warm with no heat issues what so ever. The heat sinks are almost cool to the touch.
  • MrRoboT
    MrRoboT Posts: 39
    Can you program all your componets into that pad Mickey?
  • Mikey081057
    MrRoboT wrote: »
    Can you program all your components into that pad Mickey?
    Most... So the Bluesound Nodes, The Marantz AV7702, The Oppo BDP 103D, the Directv Genie and Tidal Streaming Service are controlled by the Samsung Tablet. The only other devices not controlled are the Parasound P5 which might have a infrared app that I can find.
  • Mikey081057
    Better?
  • Wow! Eyecatching. I'm thinking of doing that w/ a couple of hsu subs....
  • Mikey081057
    Definitely interesting. Still dialing it in. Not sure I needed the subs but since they were lying around.... Walt Duflock... Definitely punchy bass fuhdamsho.
  • Mikey081057
    Better Pic
  • WagnerRC
    I am very happy with my music hall table. Very nice system Mikey
