USB Small stand fans..??
starkiller
Anyone have ones of these or know if they well without a lot of noise? Thinking of trying one out to cool down my tube amp. Thanks!
Computer room Hegeman 1 SpeakersM&K VX-80 subKenwood DP-7010Cambridge Audio CXC Transport Rega DACPrimaLuna Prologue Four AmpAric Audio Tube PreampGarage Jennings Research SquareCustom tube preampCrown XLS-1000Denon DCD-1500II Modded MSB Link DAC
nobody?Computer room Hegeman 1 SpeakersM&K VX-80 subKenwood DP-7010Cambridge Audio CXC Transport Rega DACPrimaLuna Prologue Four AmpAric Audio Tube PreampGarage Jennings Research SquareCustom tube preampCrown XLS-1000Denon DCD-1500II Modded MSB Link DAC
I have a couple of 5" computer/ audio cabinet cooling fans I can sell you. I used them to cool an amp until I had it looked at and modded. Each has an on-off-fan speed switch, ball bearing motor and can be mounted or simply set on a flat surface, and they plug into the wall on standard household current (no transformer). Very quiet too, and rated for a life of something like 30,000 hours. I used them for around 50 - 100 hours.
I paid around like $25 each, but would let them go for $30 + shipping."Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer -
I have one of these that I have plugged in to switch on with my amp to cool it down while in the cabinet. I have it pointing out of the cabinet as an exhaust to take the heat away from the cabinet. Works great and they have great customer service. It is also available in a USB version. I have never noticed the noise unless I am right beside the cabinet.
coolerguys.com/840556096955.htmlShawn
AVR: Marantz SR-5011
Center Channel: Polk LsiM706c
Front: Polk LsiM703
Rear: LSI fx
Subwoofer: SVS 20-39pci
DVD Player: Sony PS4 -
Yep I have one from cooler guys as well, one of the cheap 12$ ones. I don't notice it, but in my jungle of a house it takes a lot of noise for me to notice...Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
+1 on the coolerguys... they have what you need. I would choose one from these guys as they wouldn't sell noisy fans.My New Year's resolution is 3840 × 2160
Garage | Polk Monitor 5B's
Closet Yamaha M80 | 2 Polk MP3K subs| Yaqin MC100B with Shuguang Treasures KT 88's & CV181Z's | Tesla E83CC's | Marantz 2252B | Marantz 2385 |Polk SDA SRS 2.3 | LSiM 705's | -
Hmm, I will need to mount the fan on the left side of the shelf to blow the air away from me as I am sitting about a foot away so it needs to be pretty quiet..see pic
Computer room Hegeman 1 SpeakersM&K VX-80 subKenwood DP-7010Cambridge Audio CXC Transport Rega DACPrimaLuna Prologue Four AmpAric Audio Tube PreampGarage Jennings Research SquareCustom tube preampCrown XLS-1000Denon DCD-1500II Modded MSB Link DAC -
I don't think you will find a fan that can't be heard from a foot away. I just use quiet 12v computer fans, powered with a 5v adapter to make them even quieter. Can't hear them from about 4 feet away, and I sit 12 feet from them. But 1 foot I can still hear them easily.
http://www.newegg.com/Product/Product.aspx?Item=N82E16835214029
19dba, make an adapter.Main Surround -
Den - Rotel RSP-1068 / Threshold CAS-2 / Boston VR-M60 / BDP-05FD -
Nice, but then i would have to use a soldering iron i don't have much less the lack of any skill to use one with the peripheral neuropathy in my fingers
I suggest not allowing air from the fan to come into contact with the tubes. I had a tube crack when doing so.Vinyl, the final frontier...
Hmm, then how does one keep the heat at bay??Computer room Hegeman 1 SpeakersM&K VX-80 subKenwood DP-7010Cambridge Audio CXC Transport Rega DACPrimaLuna Prologue Four AmpAric Audio Tube PreampGarage Jennings Research SquareCustom tube preampCrown XLS-1000Denon DCD-1500II Modded MSB Link DAC
starkiller wrote: »Hmm, then how does one keep the heat at bay??
Keep heat from bothering the amp or keep the heat from bothering you?Vinyl, the final frontier...
Fan noises drive me nuts too. You could use a computer muffin fan with a thermal switch so it only runs above a certain temp, but short of using a water cooling system, there's gonna be noise.SDA SRS 2.3TL (for sale)
From bothering me
Well, went a got a clip fan from the local thrift so will see what happens
