How do I determine polarity on . . .
drumminman
a new MW6510 replacement MW I just received.
No markings at all. Should I assume that + is on the same side as the one I'm replacing? Is there some way to check this with a DMM?
As has been discussed here, I'll have to trim the rubber surround around the screw holes as well. Date of Manufacture is 11-26-2007.
Thanks!
Thanks!
Post edited by drumminman on
With a couple of leads, hook up both ends of a 1V battery to the speaker. When the speaker moves forward (and stays there, this is a DC current), then you have hooked up to the + terminal of the battery to the + terminal of the speaker .
G~Polk SDA SRS 2
Polk RTA 15tl
Polk Monitor 7C
Polk Lsi9
Infinity RS-II (modded)
Infinity RS-IIIa (modded)
Infinity RS 2.5 x 2
Magnepan 1.6QR (modded)
System: http://forum.audiogon.com/cgi-bin/fr.pl?vevol&1290711373 -
^^^^ Ditto ^^^^If you can't hear a difference, don't waste your money.
G~
I'll try that."Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer -
I had a 50% chance of getting the polarity right by guessing which was positive - I guessed wrong
So simple: hooking up with the battery leads one way made the woofer move in; reversing the leads on the battery made it move out and stay there.
Thanks for that!"Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer -
Polk SDA SRS 2
Polk RTA 15tl
Polk Monitor 7C
Polk Lsi9
Infinity RS 2.5 x 2
Is there a way to check the whole speaker cabinet at once?
Another words: Can I hook up a battery to the speaker cable posts and watch all the drivers at the same time?Mojo Audio Illuminati v3>>Quantum Byte w/LMS>>Rpi/PiCoreplayer>> Starlight 7 USB >> Mojo Audio Mystique v2 SE>>ModWright SWL 9.0 SE Signature>>Hafler DH-500 Amp+ (Musical Concepts Fully Modded)>>
1KVA Dreadnought
Marantz SA 8005
Sony PS4
"All THAT IS LOST FROM THE SOURCE IS LOST FOREVER" -
Yep.Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
Thanks vmaxer. Just a standard 1.5v battery?Mojo Audio Illuminati v3>>Quantum Byte w/LMS>>Rpi/PiCoreplayer>> Starlight 7 USB >> Mojo Audio Mystique v2 SE>>ModWright SWL 9.0 SE Signature>>Hafler DH-500 Amp+ (Musical Concepts Fully Modded)>>
1KVA Dreadnought
Marantz SA 8005
Sony PS4
That should work, I have done it on my SDA's. I don't leave it connected long as I don't know what the tweeters can take?Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
Sunfire CG 200 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
thanks vmaxerMojo Audio Illuminati v3>>Quantum Byte w/LMS>>Rpi/PiCoreplayer>> Starlight 7 USB >> Mojo Audio Mystique v2 SE>>ModWright SWL 9.0 SE Signature>>Hafler DH-500 Amp+ (Musical Concepts Fully Modded)>>
1KVA Dreadnought
Marantz SA 8005
Sony PS4
Vmax -
A 1.5v battery into an 8 ohm driver (or tweeter, for that matter), is only a hair over 1/4 watt (.28). Even at DC, not enough to hurt your tweeter:-)
― Aleksandr Solzhenitsyn -
Good to know. Thanks.Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
Sunfire CG 200 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
I used a 9 volt battery for a very brief check of my 1.2tl's as 1.5 volts didn't move all those drivers enough for me to see. Sure enough there were 2 drivers in the left speaker wired out of phase. What a difference that made once that was taken care of.
Capacitors don't allow dc to pass so your tweeters are safe -
This was a very interesting question because I had the same thing happen on my replacement 6502 for my M7s. No red dot or marker of any kind. I did not test and either guessed right or followed the beat driver's dot placement. Now I know better and now to test w/ a battery. I also have a 9v set up w/ cap and leads ready to go. If a machine lays down the surrounds why can't they trim it better to begin with ? If hand laid then for sure it should be trimmed. Polk must have gotten some complaints from unsuspecting folks that just put in their drivers and the screws ripped the crap out of the rubber surrounds.2chl- Adcom GFA- 555-Onkyo P-3150v pre/amp- JVC-QL-A200 tt- Denon 1940 ci cdp- Adcom GFS-6 -Modded '87 SDA 2Bs - Dynamat Ext.- BH-5- X-Overs VR-3, RDO-194 tweeters, Larry's Rings, Speakon/Neutrik I/C- Cherry stain tops Advent Maestros,Ohm model E
motorstereo wrote: »I used a 9 volt battery for a very brief check of my 1.2tl's as 1.5 volts didn't move all those drivers enough for me to see. Sure enough there were 2 drivers in the left speaker wired out of phase. What a difference that made once that was taken care of.
Caps act as an AC block... -
https://en.wikipedia.org/wiki/Capacitor
Caps act as an AC block...[/quote]
5th paragraph down if you'd like to skip through quickly.
Please excuse my lack of electrical knowledge . . .
To test the entire speaker, connect small 1.5 or 9 volt battery to the speaker binding posts and if in correct phase, all woofers move outward, correct?
Pre Cary SLP-05
Power Rogue M180 Dark monos
Mains Salk HT2-TL
Rythmik F12 -
That's correct GlennDog. I used a pair of wires so I could stand in front of the speaker and touch the ends of the battery very briefly. You want the battery on there just long enough to verify
I checked both speakers. The two woofers and the stereo driver are in correct phase. How do I confirm that the sda drivers are correctly phased? I did not see much movement with the battery test.Mojo Audio Illuminati v3>>Quantum Byte w/LMS>>Rpi/PiCoreplayer>> Starlight 7 USB >> Mojo Audio Mystique v2 SE>>ModWright SWL 9.0 SE Signature>>Hafler DH-500 Amp+ (Musical Concepts Fully Modded)>>
1KVA Dreadnought
Marantz SA 8005
Sony PS4
