How do I determine polarity on . . .
drumminman
drumminman Posts: 3,396
edited July 2011 in Vintage Speakers
a new MW6510 replacement MW I just received. :confused:
No markings at all. Should I assume that + is on the same side as the one I'm replacing? Is there some way to check this with a DMM?
As has been discussed here, I'll have to trim the rubber surround around the screw holes as well. Date of Manufacture is 11-26-2007.
Thanks!
Post edited by drumminman on
  • geoff727
    geoff727 Posts: 546
    edited July 2011
    With a couple of leads, hook up both ends of a 1V battery to the speaker. When the speaker moves forward (and stays there, this is a DC current), then you have hooked up to the + terminal of the battery to the + terminal of the speaker .
    G~
    Polk SDA SRS 2
    Polk RTA 15tl
    Polk Monitor 7C
    Polk Lsi9
    Infinity RS-II (modded)
    Infinity RS-IIIa (modded)
    Infinity RS 2.5 x 2
    Magnepan 1.6QR (modded)
    System: http://forum.audiogon.com/cgi-bin/fr.pl?vevol&1290711373
  • decal
    decal Posts: 3,205
    edited July 2011
    ^^^^ Ditto ^^^^
  • drumminman
    edited July 2011
    geoff727 wrote: »
    G~
    I'll try that.
  • drumminman
    edited July 2011
    I had a 50% chance of getting the polarity right by guessing which was positive - I guessed wrong :tongue:
    So simple: hooking up with the battery leads one way made the woofer move in; reversing the leads on the battery made it move out and stay there.
    Thanks for that!
  • geoff727
    geoff727 Posts: 546
    edited July 2011
    drumminman wrote: »
    Thanks for that!
    You bet. :smile:
    Polk SDA SRS 2
    Polk RTA 15tl
    Polk Monitor 7C
    Polk Lsi9
    Infinity RS 2.5 x 2
  • machone
    machone Posts: 1,561
    Is there a way to check the whole speaker cabinet at once?
    Another words: Can I hook up a battery to the speaker cable posts and watch all the drivers at the same time?
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
  • vmaxer
    vmaxer Posts: 5,120
    machone wrote: »
    Yep.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • machone
    Thanks vmaxer. Just a standard 1.5v battery?
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
  • vmaxer
    vmaxer Posts: 5,120
    That should work, I have done it on my SDA's. I don't leave it connected long as I don't know what the tweeters can take?
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • machone
    thanks vmaxer
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
  • daddyjt
    daddyjt Posts: 3,124
    vmaxer wrote: »
    Vmax -
    A 1.5v battery into an 8 ohm driver (or tweeter, for that matter), is only a hair over 1/4 watt (.28). Even at DC, not enough to hurt your tweeter:-)
    ― Aleksandr Solzhenitsyn
  • vmaxer
    vmaxer Posts: 5,120
    Good to know. Thanks.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • I used a 9 volt battery for a very brief check of my 1.2tl's as 1.5 volts didn't move all those drivers enough for me to see. Sure enough there were 2 drivers in the left speaker wired out of phase. What a difference that made once that was taken care of.
    Capacitors don't allow dc to pass so your tweeters are safe
  • This was a very interesting question because I had the same thing happen on my replacement 6502 for my M7s. No red dot or marker of any kind. I did not test and either guessed right or followed the beat driver's dot placement. Now I know better and now to test w/ a battery. I also have a 9v set up w/ cap and leads ready to go. If a machine lays down the surrounds why can't they trim it better to begin with ? If hand laid then for sure it should be trimmed. Polk must have gotten some complaints from unsuspecting folks that just put in their drivers and the screws ripped the crap out of the rubber surrounds.
  • Msabot1
    Msabot1 Posts: 2,098
    Caps act as an AC block...
  • https://en.wikipedia.org/wiki/Capacitor
    Caps act as an AC block...[/quote]
    5th paragraph down if you'd like to skip through quickly.
  • GlennDog
    GlennDog Posts: 3,156
    Please excuse my lack of electrical knowledge . . .
    To test the entire speaker, connect small 1.5 or 9 volt battery to the speaker binding posts and if in correct phase, all woofers move outward, correct?
    Pre Cary SLP-05
    Power Rogue M180 Dark monos
    Mains Salk HT2-TL
    Rythmik F12
  • That's correct GlennDog. I used a pair of wires so I could stand in front of the speaker and touch the ends of the battery very briefly. You want the battery on there just long enough to verify
  • machone
    I checked both speakers. The two woofers and the stereo driver are in correct phase. How do I confirm that the sda drivers are correctly phased? I did not see much movement with the battery test.
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
