Newbie SDA2 owner here... WOW!
flot-a-tone
First off, thanks to all the knowledgable folks that contribute here. This forum looks to be an incredible resource.
It has been 16 odd years since I made an effort to have a 'decent' vintage home stereo system.... ( on a budget...)
Three days ago... I picked up a nice set of Polk sda2 speakers at what I consider to be a stupid good price... When I bought them there was no IC cable, so I crudely made something that works... And... WOW... For me, this setup is fantastic... I will, over the next few months toy with proper upgrades, simply to have some fun and learn something along the way...
Thanks Mr. Polk! I am absolutely blown away and I think...
HOOKED!
HOOKED!
Thanks!
Today I found a second identical pair on the cheap! The cabinets look a little cleaner, so they might be donors, or maybe I'll try for 4 of them in my basement music room!
I'm sitting here listening to Mark Knopfler like I've never heard him before...
Did I say WOW already?
Cheers!
Maybe -
Welcome to CP. You don't want two pairs operating simultaneously in the same room, unless you're doing a 5.1 setup. The Interaural Crosstalk Cancellation from each pair will interfere with the other pair.Home Theater/2 Channel:
dhsspeakerservice.com/ -
ooooooooooooooh
Thanks for that info!
Looks like i've got SDA for two rooms now then!
Congratulations on great speakers. Stick around and we will help empty your wallet.
Welcome to the forum!!Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
Sunfire CG 200 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
I am new to the polk sda 2s as well I have had mine for 2 weeks and I love the sound. I will end my speaker hunt here, I went from white van speakers to pioneer cs-603 to cerwin vega d-9s and then to a pair of monitor 10s that I thought were amazing until I took the sda 2s home. I hope you enjoy your as much as I do.
And take those SDA's to a level that will amaze you even more!"Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer -
SDA2 speakers are 4 Ohms. I know I'm not getting what I can out of them. Can anyone recommend a good receiver, easily attainable to properly power these speakers?
and dip lower than that no receiver will hold up to them for long...you will need an amp. Yes a receiver will make sound come out of them BUT you will blow tweeters and maybe blow drivers.
