Where to purchase surrounds for 1.2tl mid bass drivers?
Making good progress I see.
The voice coils under the dome are cooked likely due to ferro fluid failure as by now it has turned to sludge. The RD0198-1 is a better tweeter anyway. -
By chance did you put that RTV on the inside also?
No, I put the RTV on the outside only. 2 reasons: 1. The basket pillars are really wide making rear access difficult for a guy like me with ham hands and stone fingers. 2. I was trying to keep the RTV layer as thin as possible to minimize it's effect on surround compliance.
Main System
Carver Gear: C-11 (refit & modded, w/balanced outs), M-500 (refit), M-500t(x2) (refit), M-1.0t (refit & upgraded), SD/A 490t, TX-11b
Other Electronics: Behringer CX3400, Behringer FBQ3102, Furman PS-8R-II, Nikko NPS-1, Teac C-3RX, Technics SL-D303
Speakers: Legacy Audio Custom Super Satellites (new drivers & bi-ampable XOs), Legacy Audio Custom Subwoofers
Carver Office System: C-2 (refit & modded, w/balanced outs), DTL-50, M-200t, TX-2, Musical Fidelity X-10D, Design Acoustics DA-30 (DA-20LF sub w/4 DA-10 satellites)
Workshop System: Carver MXR-130 receiver, Carver DTL-50 CDP, Design Acoustics DA-30 (DA-20LF sub w/2 DA-10 satellites)
Son's System: Carver CT-7, Carver DTL-200MK2, Carver M-1.5t (refit), Hitachi PS-38 (TT), Polk SDA-SRS 1.2tl, Klipsch KG2.5, PSB Century Subsonic 2i powered sub
Not In Use or Need Repair: Denon DCM-35 (CDC), Teac X10R (RTR), Technics SL-1200MK1 (TT), Yamaha CDX-820 (CDP) -
Tweeter is toast. By chance did you put that RTV on the inside also?
I believe what pitdogg2 was concerned about, is the off-gas RTV Silicone releases as it cures. It's very acidic, and will attack any exposed metal inside the cabinet. RTV should never be used internally in a speaker cabinet.Home Theater/2 Channel:
dhsspeakerservice.com/ -
I don't think the product I used to seal the rips and tears would be an issue even if I had put it on the inside and immediately reinstalled the drivers. Permatex Ultra Black RTV Gasket Maker is intended for contact with metal. I've used it to seal butyl rubber surrounds in the past. As for longevity at least one of the drivers I used it in is still air tight after 10 years of regular use in a PA sound application. I intend to replace these drivers long before that.
Allow me rephrase my earlier question. Is there a reason that the same tweeters - T2 and T3 - failed on both speakers?Main System
Hard to say without knowing the history of the speaker and how it was used. Could simply be age as already suggested, abuse from being over driven, etc.
IMHO, I think what you'll find is eventually you'll be replacing every part of the speakers and that's gonna cost some coin. If you do it slowly over some time the hit won't be as bad.....but interest may fade too over time. Good luck to you and enjoy them.
lsi 9's -
The wife of a friend was the original owner. The speakers hadn't been used regularly in about 10 years and they were never driven hard. Most of the damage (grill cloth, surrounds) was done by their cats who loved to perch atop them. The couple had retired and was moving into a smaller home. They gave them to me and I'm restoring them for 19 y/o son who is a rising sophmore at MIT. (He also is a talented drummer who inherited my love of music and electronics.) I hope to have them back to original condition (or better) by the time he graduates.
Main System
They could have been under driven too, not enough power is about as bad as too much.....at higher volumes anyway.
Anyway, nice project to do with the son, hope he'll appreciate them when they are done. Keep us posted on your progress. Cheers.HT SYSTEM-
lsi 9's -
Ain't that the truth. Clipping an amp will fry a tweeter faster than you can shake a stick at it.They could have been under driven too, not enough power is about as bad as too much.....at higher volumes anyway.
Zack and I have done quite a few projects together. In this case his contribution was to he help me load them in the truck, cart them home from DC, and haul them up to his 2nd floor bedroom. He only had a couple of days to enjoy them before he headed off to school but he was impressed despite the issues.Anyway, nice project to do with the son, hope he'll appreciate them when they are done. Keep us posted on your progress. Cheers.
I'm already finished patching the mids and sealing the cabinets, and I'll have the cosmetic issues resolved in a week or two. After that I'll refurbish the crossovers and replace the dead tweeters. Of course I have plenty of my own projects to work on so I figure by the time I get around to upgrading the mids Zack will have graduated.
Ciao for now!Main System
As far back as I can remember I had more to do than I had time to do it with. Didn't change much until I retired. Now I have plenty of time but perhaps not so many years so this advice from Pablo Picasso rings true: “Only put off until tomorrow what you are willing to die having left undone.”.Main System
WOW you get it so many that fly by here do not. I couldn't count the amount of time we have tried to convey that message only to get " I still had 1/2 of the dial to go no way was I clipping"....
Dom ain't no spring chicken and has been around the block three or four times lol...."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
EndersShadow wrote: »
Good thing I resemble that or I might take your ageist remarks poorly
Main System
Lol... Hey I never said just HOW old you are... Lol...
And maybe the around the block was about your immense knowledge and not age
EndersShadow wrote: »EndersShadow wrote: »
Now you're just brown-nosing. Please continue.
Main System
I finished recovering the side panels for the right speaker yesterday. The wood accent panels made it tricky to get a smooth, flat edge but I'm pretty happy with the result.
side panels before:
side panels after:
finished speaker:
Main System
Thanks pitdogg2.
I should have the left speaker recovered by the weekend. Then I'll start looking at repairing, replacing or upgrading the 4 dead tweeters (T2 and T3 on both speakers).Main System
I like your project, and I like your writing style/humor. Please stick around the forum even after your repairs are complete!Jay
Well thanks agfrost. Seems like a friendly (and knowledgeable) group of people, and a lot of my Carver Site friends are here, so I might just do that.Main System
nooshinjohn wrote: »Anyone want do a go fund me page to help out in the restoration?
John, nice idea, and I'm sure some Polkies around here might have a driver or two they could help out with too...possibly.
Does anyone out there have any SL3000's they'd be willing to donate? 4 of Zack's are dead and we'd really like to hear what the 1.2tl's sound like before we start upgrading. I'm willing to do craftwork in trade. I can buff out scratches on your turntable dust cover, repaint your chassis cover, replace your power cord or upgrade it to IEC. Here's a few photos of some of my recent projects:
various amp and preamp cover restorations:
turntable restoration (damaged during shipping):
PA rack patch panel and wiring harness:
IEC socket template:
IEC socket and balanced connector installations:
remote 9 pin socket for a Marshall guitar amp head for easy tube rolling:
AC cord cable tray installation:
Main System
I finished recovering the grills and side panels over the weekend. Now I need to get them to sound as good as they look....
Main System
Hey Dom, how are things going?? Time for an update.
Best of luck to you.Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
Thanks Billy. I've been checking out the crossovers to determine if it's OK to install your tweeters. Had a few questions about what I found so I started a new thread which is "awaiting moderation". Either I'm on probation for posting that trade offer in the FS/WTB forum or maybe it's because there's a link in it (back to this thread). Either way I'll post a link to the new thread here once it has been approved.Main System
It's not that it's the forum software being dumb... It thinks your a spammer likely for posting links or videos... I had it happen when I tried to post my Carver M1.0t MKII here.
Your not in trouble lol....
I saved a draft of my new thread. Should I delete the link and try posting it again?Main System
I don't want to bother anyone. If it hasn't been approved by the AM I'll repost without the link.Main System
I check the Spam Queue section three times a day and "release" all the trapped non-spam discussions and deal with all the real spam that gets collected.
Thanks Ken.
Here's the link to the new thread ==> http://forum.polkaudio.com/discussion/comment/2164122#Comment_2164122Main System
