Cord for PSW111
I'm afraid I have lost the power cord for the PSW111. However, I have a three prong cord that reads "10a 125 Volt". The back of the subwooder reads "120 volt". Can I use this three prong cord to power the subwoofer? The fuse actually blew when I attached the cord, so I am guessing that the answer is yes. If not yes, that means the subwoofer has some sort of issue.
If the cord does not work, can you tell me how to locate an appropriate cord for the subwoofer?
Thanks,
Todd
  • [Deleted User]
    Hello Todd,
    Welcome to Polk's forum. You should be fine with any, good quality IEC type, AC power cord and certainly 10A is perfectly fine.
    However, it seems that your unit's bass amplifier needs some service attention. It would be best to contact Polk's CS department at either 1-800-377-7655 or via email to polkcs@polkaudio.com. If you've owned the subwoofer for less than three years have the original date and place of purchase and the serial number when you contact them.
    Regards, Ken
  • proftod
    proftod Posts: 2
