FS: PC Motherboard and CPU
I just upgraded the gaming PC and I've got a killer motherboard/CPU combo for sale. This is the Maximus Gene V Z77 motherboard and Intel 3570k CPU. There are the base of the rig I built and talked about here starting on page 2
This is an excellent performing combination and overclocks like a beast. I had the CPU on water cooling from the day I built it and I had the Cpu warning temp set at 60 degrees just because I'm super paranoid about that. With my setup the CPU ran at 4.4Ghz and never saw temps above 60 degrees, so it's been babied.
Here's a link to the motherboard:
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131830
And a link to the CPU:
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116504
I'm selling them as a pair for a couple reasons, a) I know they're a perfect match and are compatible and b) I have the box for the motherboard but don't have the box for the CPU readily available. I also don't have the cooler for the CPU since I never opened it and don't have the box available. You're not going to want to use the stock cooler on this setup anyway, this whole rig is built for performance and overclocking and you'll want something better than the stock cooler anyway. I believe I do have the box somewhere in storage so if it's an absolute deal breaker I can make a trip out to the storage unit and locate it but it'll take me a couple days.
So you'll get the motherboard with the CPU installed which will ship in the original motherboard box. Aside from the motherboard and CPU in the box you'll also find several SATA cables, the SLI bridge, the mPCIe combo card, a fan controller and the ROG USB cable.
I'd like to get $250 for the combo
  • AsSiMiLaTeD
    AsSiMiLaTeD Posts: 11,728
    I gonna lower my price to $225, you won't find a more powerful setup on the planet for this price.
  • vmaxer
    vmaxer Posts: 5,121
    How much is shipping?
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • vmaxer
    vmaxer Posts: 5,121
    @AsSiMiLaTeD
    Shipping cost??
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
