FS: PC Motherboard and CPU
AsSiMiLaTeD
I just upgraded the gaming PC and I've got a killer motherboard/CPU combo for sale. This is the Maximus Gene V Z77 motherboard and Intel 3570k CPU. There are the base of the rig I built and talked about here starting on page 2
This is an excellent performing combination and overclocks like a beast. I had the CPU on water cooling from the day I built it and I had the Cpu warning temp set at 60 degrees just because I'm super paranoid about that. With my setup the CPU ran at 4.4Ghz and never saw temps above 60 degrees, so it's been babied.
Here's a link to the motherboard:
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131830
And a link to the CPU:
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116504
I'm selling them as a pair for a couple reasons, a) I know they're a perfect match and are compatible and b) I have the box for the motherboard but don't have the box for the CPU readily available. I also don't have the cooler for the CPU since I never opened it and don't have the box available. You're not going to want to use the stock cooler on this setup anyway, this whole rig is built for performance and overclocking and you'll want something better than the stock cooler anyway. I believe I do have the box somewhere in storage so if it's an absolute deal breaker I can make a trip out to the storage unit and locate it but it'll take me a couple days.
So you'll get the motherboard with the CPU installed which will ship in the original motherboard box. Aside from the motherboard and CPU in the box you'll also find several SATA cables, the SLI bridge, the mPCIe combo card, a fan controller and the ROG USB cable.
I'd like to get $250 for the combo
I gonna lower my price to $225, you won't find a more powerful setup on the planet for this price.
How much is shipping?Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
Sunfire CG 200 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404
