Cartridge question
285exp
285exp Posts: 43
edited September 2004 in 2 Channel Audio
Recently inheirited a turntable and collection of mostly classical LP's, 50's to 80's vintage. The turntable works fine, but the stylus of the Shure V15 type IV cartridge is broken. I understand that this model has been out of production for some years, and that Shure doesn't have any replacement styli. Any suggestions on where to find vintage styli? What would a new cartridge of similar quality run? Any suggestions on others to consider? Thanks
Post edited by 285exp on
  • dorokusai
    dorokusai Posts: 25,576
    edited August 2004
    What model turntable?
  • 285exp
    285exp Posts: 43
    edited August 2004
    Sony PS-X5, direct drive semi auto, early 80's vintage.
  • Frank Z
    Frank Z Posts: 5,860
    edited August 2004
  • 285exp
    285exp Posts: 43
    edited August 2004
    Thanks for the site Frank. I found a "replacement", but it does not appear to be a genuine Shure stylus. Doesn't specify who the mfg is. Are these generally of comparable quality to the originals or is this likely to be just a crapshoot? Am I better off just buying a new cartridge? Thanks for your help.
  • dorokusai
    edited August 2004
    You should email www.shure.com and ask them they recommend as a stock replacement. Out of production is fine, but they should have a suggestion or option for you.
  • Tour2ma
    Tour2ma Posts: 10,177
    In case this question is still out there...
    Shure was substituting the stylus for their V15-III (VN35HE or MR, I believe) for the type IV's. Only difference is that the type III stylus does not have the IV's dynamic stabilizing brush on it. However, I am not sure that the type III stylus is still available.
    Here's the link to Shures replacement chart:
    http://www.shure.com/phono/xrefphono.html
    They recently moved there service organization into HQ, but I think this toll free will still get to the right place:
    1(800) 516-2525
    Ask about their stylus exchange program.
    You do see VN45MR's on ebay just about weekly, but they can get a little pricey, i.e., $90 or more...
    Good luck
    More later,
    Tour...
    Vox Copuli
