Warped Vinyl?
msg
msg Posts: 10,564
Hey, any of you vinyl fiends ever come across warped vinyl and know of a good safe way to fix it?
  • voltz
    voltz Posts: 5,384
    here is a link I remember P-Man giving me...I have a Eagles greatest hit thats warped super badly but I have not tried it yet!
    http://m.wikihow.com/Fix-a-Warped-Vinyl-Record
    msg Posts: 10,564
    ah, interesting.
    the album I need to fix is kind of rare, so I'm a bit concerned about doing this correctly.
    I don't have many albums, none to practice on!
    You can always put it between 2 heavy pieces of something and stick it in the garage for awhile. Garages definitely get warm in the summer but not oven warm in case your worried about it. Just make sure the weight is evenly distributed.
    BTW....you sure it's the album that's warped and not the operator ? :)
    gudnoyez Posts: 8,194
    I just leave them in the Jacket sit them out in the sun and put a heavy cinder block on them sometimes it works sometimes it dont.
  • pumpkinman
    pumpkinman Posts: 10,415
    I have a TT outer ring which works great with warped vinyl.
    http://www.ttweights.com/usainternational-estore.html#!/New-Products/c/10943506/offset=0&sort=normal
    P-man
    Because I am The Pumpkinking
    For the price of those rings.....stick it in the garage under something heavy. ;)
  • agfrost
    agfrost Posts: 2,486
    Jay
    txcoastal1 Posts: 13,519
    agfrost wrote: »
    LOL, go buy a new record...still laughing
  • Nightfall
    Nightfall Posts: 10,083
    Nearly $3,000? Riiiight...
    afterburnt wrote: »
    Village Idiot of Club Polk
  • pumpkinman
    I believe that the outer ring helps with any LP and not just warped vinyl.
    Cost to much ?? Not to me. You must remember I wait for the fat cats to start vinyl and get quickly get tired of it. That usually saves me 60% on audio goodies. This guy was desperate to sell and I bought it for $100. ozsy5dtctnk7.gif
    msg Posts: 10,564
    thanks for all the input here, guys.
    I think I'd like to try one of those clamps. I like the idea there, both warp correction and damping.
    P-man - those TT rings are kinda neat too. do you use just a ring, or a ring + clamp? not quite understanding how they work, exactly, so I'll check those out
    for now I went ahead and ordered the Furutech disc flattener that agfrost recommended; two in fact. I mean, a real no brainer there, being so affordable and all.
    voltz wrote: »
    Thanks D, good stuff, yeah, I was reading about something similar; this is a good tutorial.
    I think I might try the glass or something, but just in the garage like Tony suggests, not the oven. and let it cool flat. maybe that's all it'll take. I'm not sure whether it was already warped, or if happened in the car on my way home from the shop last Summer during a 2hr stop at a coffee shop one warm eve. I was conscious of the possibility and had the albums flat on the floorboard, so, not sure. as Keiko mentions, and as I've seen in comments on threads/vids demonstrating this method, it seems that people have had mixed results, sometimes ending in damage. I can find this album again for $50 - $100, but seems I'd want to find a way to address this safely moving forward, as well, in any other albums I happen across. I really only pick up my absolute faves, but seems like they're all hard to find. I probably just need to find some better shops to deal with.
    with my luck, I'd end up with this. but it's a double album, so at least I'd have two
  • agfrost
    In all seriousness, I remembered that several years ago a handful of guys here (Rockford Audio Society?) went in on the record flattener and shared it for all to treat their discs that needed it. Rich, Carl, Ricardo, Ted, and others...
    I couldn't find the thread last night using the Vanilla search function but got it now using Google.
    The price was "affordable" back in 2008. :wink:http://forum.polkaudio.com/discussion/61601/tales-of-the-furutech-flattener
    Jay
    Jay
    msg Posts: 10,564
    wow, yeah, much cheaper. looks like those guys got great results, too.
  • pumpkinman
    I use a weight not a clamp. Would you like to try one out ?? What table are you using ??
    msg Posts: 10,564
    oh, gotcha - weights and clamps both sit on the spindle though, right? only a clamp puts positive downward force?
    I'm in between tables right now, and not really sure where I'll end up quite just yet. I was just getting started last summer and was using Audio Technica's midline(?) LP120. gathered a few of my faves just to see what it was all about, but gave it up. feeling inclined to give it another shot, or at least get set up again to have the option.
  • tratliff
    tratliff Posts: 1,826
    Scott - you better watch it...You are about to jump off in the vinyl rabbit hole. I have found a new appreciation for it. After getting the new phono pre my vinyl never sounded better. Spent 20'ish hours last weekend and never even put in a cd or High Rez.
  • Nightfall
    tratliff wrote: »
    What preamp? I've been looking at this one:
    Silk Audio (Yaqin) MS-23B because of the tubes and price
    http://www.ebay.com/itm/Silk-Audio-MS-23B-Tube-Phono-Stage-from-same-factory-as-Yaqin-/221812195967?pt=LH_DefaultDomain_0&hash=item33a509827f
    afterburnt wrote: »
  • seabeast
    seabeast Posts: 8
    What album is it?
    msg Posts: 10,564
    tratliff wrote: »
    niiiiice! hehe, I hear ya man, thanks for the warning. sometimes you don't know it's got'cha until it's too late, right?!?
    seabeast wrote: »
    What album is it?
    Luna Live
    you know of good sources for vinyl?
  • seabeast
    seabeast Posts: 8
    None you cant find most likely.i live in ft.pierce,fl. There's a couple vinyl stores near here.
  • tratliff
    Nightfall wrote: »
    tratliff wrote: »
    Nightfall -
    I first used a parasound P3 and P5. It never impressed me. Then when I purchased my new pre-amp (Cary SLP 05) I needed a separate phono pre, so I purchased a used Parasound zPhono. That was a real upgrade. After using the zPhono for a little bit I got a Parasound JC3. I am really liking it.
    msg Posts: 10,564
    T - what would you say was the most significant upgrade piece, the zPhono or the JC3? significant improvement with JC3 over zPhono?
  • cmy330go
    cmy330go Posts: 2,341
    HT
    Mits WD-65737, DirecTV, Oppo DV-970HD, XBOX ONE, Yamaha RX-A1030, Parasound Halo A23, Rotel RB-985, Music Hall MMF-7, Parasound PPH-100, LSi-15, LSi-C, LSi-FX, LSi-7, PSW-1000, Monster HTS2600
    2 CH
    Parasound Halo P3, Parasound Halo A21, Sutherland Ph.D, VPI Classic 3 w/ 3D arm & Soundsmith Aida Cartridge, Arcam CD72T, B&W 802 S3, Monster HTS2500,
    msg Posts: 10,564
    edited July 2015
    Skip good to point out, thanks. reading back, I see that my question was a bit incomplete/vague, and I think I misread/understood Todd's post at first. he was talking about how good apples are, and I'm asking whether he likes tangerines better than oranges. not sure where I was yesterday. Pluto. yes, musta been Pluto. thinking now that "Cary" and its requirement for a phono pre didn't even register? haha wtf...
    after reading back, indeed, I understand that it was probably the Cary and "a" phono pre that was the "real upgrade" move - most significant; more than from the zPhone to the JC3 - and that's what I was meaning to ask.
    I am curious as to the experience in going from the zPhono to the JC3, as well, though.
    Post edited by msg on
  • Jimbo18
    Jimbo18 Posts: 2,351
    edited July 2015
    We used to tape a nickel on top of the cartridge. You could try that. :)
  • tratliff
    edited July 2015
    I think Skip is correct. The biggest improvement was the Cary. When I upgraded to the Cary I had to jump off into separate phono pres. I cannot comment on how the zPhono would have sounded with the P3 or P5 but the improvement I had once I upgraded the pre and phono pre was significant.
    To answer your question Scott, about the difference in the zPhono and JC3. While the JC3 is more musical (less noise, blacker background, slightly more detail) I think it is like most other equipment upgrades. For the cost of the 2 pre's being compared I am not sure the difference is worth the extra cost. Considering the JC3 cost roughly 10-15 times more than the zPhono.
    But then again I did not actually pay for the JC3. I traded my Halo A21 for it. So the upgrade was well worth it to me since I already had the A21 and no one was looking at it when I tried to sell it. At least that is how I convinced myself of the trade.
    With all things considered I am very happy with the JC3. It works well with my system and will more than likely be the last phono pre I purchase. It now has moved me to question if my turntable/cartridge should be upgraded.
    msg Posts: 10,564
    gotcha, yeah, although I see it now, I don't think it registered at first that you hadn't been able to use the Cary without addition of a phono pre, dehr, so yeah, I see now that it was the combo, and most likely the move to the Cary from the P5, making the more significant difference overall.
    good info here Todd, thanks, and a good chuckle seeing more refined rabbit-hole tunnels unfolding before you, hehe :)
