Oppo 93 to Sony x850b hdmi issue
My oppo 93 works perfectly on my old LG but does not play well at all with my new Sony. When I even connedt a known good hdmi between the two, the oppo freezes up and will not even allow the eject button to be used. Stand alone, and it works just fine. Any one have even the slightest clue on this?
    gudnoyez Posts: 8,174
    Does it at least recognize it and display the Oppo logo when you switch the input to Blu/Dvd on the remote, or does it say Blu Ray player not detected?
    nooshinjohn Posts: 26,002
    Yes... Should have stated that. The oppo logo appears on the tv but the re are no functions at all from the player that work. Not even the eject button.
    txcoastal1 Posts: 13,519
    I googled.....oppo 93 locks up on sony tv and this is what came up
    previous Official release version BDP9x-80-0513 - OPPO ...
    https://www.oppodigital.com/blu...bdp-93/bdp9x-firmware-80-0513.asp...
    Jun 3, 2014 - Resolved a HDMI handshaking issue introduced by a Sony firmware update to ... locked up once its HDMI 1 output was connected to the television. ... If both the TV tuner and the BDP-93/95 player were connected to the same ...
    https://www.oppodigital.com/blu-ray-bdp-93/bdp9x-firmware-80-0513.aspx
    Hope this helps
    Cheers
    Ron
    Thanks TX.. I will do the downloads tomorrow. Getting that sucker on the wall today way a big project. Everything was measured and re measured ten more times. I even had to factor in the opening of my turntable lid.
    Thanks again.
    edited July 2015
    Should be noted the vast majority of these 4k TV's need updates immediately. Always do the updates when you first plug them in and set up. You can also find calibration settings online.
    John, how's the pic quality bro ?
