Oppo 93 to Sony x850b hdmi issue
nooshinjohn
My oppo 93 works perfectly on my old LG but does not play well at all with my new Sony. When I even connedt a known good hdmi between the two, the oppo freezes up and will not even allow the eject button to be used. Stand alone, and it works just fine. Any one have even the slightest clue on this?
Does it at least recognize it and display the Oppo logo when you switch the input to Blu/Dvd on the remote, or does it say Blu Ray player not detected?Home Theater
Yes... Should have stated that. The oppo logo appears on the tv but the re are no functions at all from the player that work. Not even the eject button.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
I googled.....oppo 93 locks up on sony tv and this is what came up
previous Official release version BDP9x-80-0513 - OPPO ...
https://www.oppodigital.com/blu...bdp-93/bdp9x-firmware-80-0513.asp...
Jun 3, 2014 - Resolved a HDMI handshaking issue introduced by a Sony firmware update to ... locked up once its HDMI 1 output was connected to the television. ... If both the TV tuner and the BDP-93/95 player were connected to the same ...
https://www.oppodigital.com/blu-ray-bdp-93/bdp9x-firmware-80-0513.aspx
Hope this helps
Cheers
Ron
Thanks TX.. I will do the downloads tomorrow. Getting that sucker on the wall today way a big project. Everything was measured and re measured ten more times. I even had to factor in the opening of my turntable lid.
Thanks again.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
Should be noted the vast majority of these 4k TV's need updates immediately. Always do the updates when you first plug them in and set up. You can also find calibration settings online.
John, how's the pic quality bro ?HT SYSTEM-
