How much power for Polk RTI A9's???
24
  • aicardi
    aicardi Posts: 27
    if I'm spending this much money on speakers they're going to be good for a long time right ? lol
  • Nightfall
    Nightfall Posts: 10,084
    aicardi wrote: »
    Many of us here have 30+ year old Polk speakers that still get used daily.
    afterburnt wrote: »
    Village Idiot of Club Polk
  • aicardi
    aicardi Posts: 27
    great does any 1 no where to get refurbished equipment in canada?
    thanks u guys have really helped alot
    tonyb Posts: 33,072
    A lot of hi-fi shops up there sell used gear, check them out. Also....as to your inquiry about lasting a long time, as long as proper care is given ...yes they will. That doesn't mean you can bury the volume dial and expect them to last forever.
    US Audio Mart has a Canadian version also.....as well as your local craigslist.
  • mikeyb128
    mikeyb128 Posts: 2,885
    As tonyb said Canuck audio mart is a great place. I picked up several bargains there. It is pretty tough to find deals up here. There are some to be had though. Or bite the bullet and buy something new. And you don't have to worry.
    2 channel:
    Theater:
  • aicardi
    aicardi Posts: 27
    this site is hard to use im looking for a 200-400 wpc 5 Channel amp and im finding everything but that :s any suggestions on how to find anything on the site maybe a specific keyword or something i'm finding things like tube amplifier and solid state amplifiers and I have no idea what this means ??
    tonyb Posts: 33,072
    You want solid state amplifiers. Narrow your search by adding it into the search area on the left towards the top.
    Try HI-FI SHARK too.....
  • aicardi
    aicardi Posts: 27
    am i looking for class a b c or d? is there a difference?
  • Nightfall
    aicardi wrote: »
    With the power you're looking for you want class AB. 400wpc class A would really be something though.
    afterburnt wrote: »
  • aicardi
    aicardi Posts: 27
    im planing to buy the rxa1040 can that run my 4a9s safely just until i can pull some more cash together maybe A couple of months ?
  • jeremymarcinko
    jeremymarcinko Posts: 3,785
    aicardi wrote: »
    If you set them as small and the crossover to 80hz for the sub, then you will be fine.
  • aicardi
    aicardi Posts: 27
    awesome !! thanks a tun guys i will definitely be back too learn more :D
    tonyb Posts: 33,072
    .....and don't try and bury the volume dial.
  • aicardi
    aicardi Posts: 27
    bury the volume? loke max ut out u mean ??
  • Nightfall
    aicardi wrote: »
    Yes. If you hear audible distortion you were doing damage to your speakers long ago on the volume dial.
    afterburnt wrote: »
    tonyb Posts: 33,072
    You never want to max out the volume dial, under any circumstances....with or without an amp.
  • aicardi
    aicardi Posts: 27
    good to no lol
  • aicardi
    aicardi Posts: 27
    is there a difference between a five channel car amplifier and a five channel home theater amplifier ??
  • Inspector 24
    Inspector 24 Posts: 1,308
    To start, one plugs into 120V AC from your wall, the other off a cars 12v DC system.
    Up
    LSi15 LSiC - RX-V3000
    Down
    Sim2 D60 - Dragonfly 106" Panny 500
    tonyb Posts: 33,072
    aicardi wrote: »
    Yes, don't even think about it. lol
  • aicardi
    aicardi Posts: 27
    there soo much cheaper
    i just got ma a9s 2day there beautiful!!! huge but in an awesome eay lolcant wait to get set up
  • Nightfall
    aicardi wrote: »
    Sure, you just have to bring a car battery into your house as well as put it on a trickle charger every night or buy a 120v to 12v DC converter which is going to be at least an extra $100. It would be a lot of hassle for a lot less sound quality.
    afterburnt wrote: »
  • aicardi
    aicardi Posts: 27
    ok so just to be sure im hooking up my 4 a9s to a yamaha rxa1040 with 12 guage speaker wire and set my speakers to small? not large?
    txcoastal1 Posts: 13,513
    edited July 2015
    with sub---small,
    w/o ....large
    without amp or sub for 4-A9's....large front, small year
  • aicardi
    aicardi Posts: 27
    no amp yet looking into xpr-5
    n i have 2 subs
    thanks n sick pic
  • aicardi
    aicardi Posts: 27
    oh and whats a save volume like 75% ish or is that considered to loud since im not using an amp yet?
    F1nut Posts: 51,799
    Recommending a volume level with an AVR isn't the same as with a 2 channel pre amp. Your AVR likely uses the dB scale, so with those speakers and that AVR I doubt you would be able to go past -20dB without damaging something.
  • Nightfall
    edited July 2015
    aicardi wrote: »
    When the sound stage collapses and it starts to sound shrill and stressed, you've gone too far. If a protection circuit, polyswitch, or fuse trips you've gone WAY too far.
    afterburnt wrote: »
  • aicardi
    aicardi Posts: 27
    based on what you all said and since my ears are not fine-tune enough to hear when the clipping starts lol
    ive decided to block the max volume at 22.5 my avr goes from -80db to +16db
    at-20 sounds clear to me bit -22.5 is perfect for movies n going lower cant hurt righ
    after all i can put it much louder once i get the amp:D till then this will due just fine
  • Thorton
    Thorton Posts: 1,324
    nbrowser wrote: »
    aicardi wrote: »
    As I've found it may not go exceptionally "louder" maybe a bit but at the higher volumes the dynamics will be vastly improved. Sound won't get compressed or break down so easily. Remember, to get an additional 3Db of loudness you literally have to double the power to feed to a speaker as a general rule of thumb. That said the serious improvements in dynamics will be a rather good experience.
    Agree.
    Aicardi, nice set-up. Once you add a nice amp to the system, I believe you'll be amazed at the performance difference in the A9's. They really like clean power and are a very good dual purpose speaker.
    DAC: Bricasti M1SE
    Pre/Pro: Marantz AV8805
    Subs: 2 - Rythmik F25's
