AVA amp?
I'm still looking for something to pair w/ the 703's while getting
the fundage together. Audio by Van Alstine are in reach. I've read some
old comments from this site but... Does/did anyone run one of
his SS amps and what did you think?
  • [Deleted User]
    [Deleted User] Posts: 10,716
    I should add that I'm looking for something in the 200 watt range that
    is tube sounding w/out tubes. :# The new Vincent would be ideal but
    A) don't have that king of scratch and B) I fear soldering tubes as much
    as tubes. Well, I don't fear tubes but a tube amp isn't going to work well
    in my system. Under two G's seems to be the upper limit...
  • voltz
    voltz Posts: 5,384
    edited July 2015
    on audiogon there are a few parasounds for good prices...the 125 wpc A23 and the 250wpc A21
    http://app.audiogon.com/listings?utf8=✓&global_search_text=parasound
    tonyb Posts: 33,072
    edited July 2015
    McCormack....and you can stop right there for SS with a tube like flavor. Pass would be my other choice but way too expensive.
    The other guys I've talked into the McCormacks are still trying to find their nose 'cause their sack is stuck to their face.
    Or....I can sell ya my Butler for 1700 shipped. A tubed hybrid which you'll never have to swap out the tubes, can't actually. It's a TDB2250, you can check it out at Butler audio.
  • [Deleted User]
    Thanks voltz. Always forget about audiogon for reason...
    voltz wrote: »
  • [Deleted User]
    Thanks for the leads Tony!
    tonyb wrote: »
