SDA CRS vs Monitor 7
I have a set of M7's, love em. There are some SDA CRS for sale ($200) that look to be good condition. I was thinking wood bar stools would make good stands. Would those be an upgrade from the M7? How is the bass from the CRS?
  • westmassguy
    westmassguy Posts: 6,850
    Which version are they? 84' 2nd generation CRS with two tweeters, 86' 3rd Generation CRS+ with single tweeter, or 87'/89' 4th generation CRS+ with single tweeter? The 2nd generation is less desirable, followed by the 3rd. All of them will outshine the Monitor 7s, providing you like the interaural crosstalk cancellation provided by the SDAs. I would not use a bar stool as a stand. The original drawing for the stands is in the vintage SDA schematics section. You could also purchase or make suitable stands, that will put the tweeters at the correct height.
    Home Theater/2 Channel:
    dhsspeakerservice.com/
  • telemike
    telemike Posts: 115
    They are first gen with two tweeters
  • westmassguy
    I would pass, and wait for a later generation. 4th generation would be my first choice, 3rd generation 2nd choice.
  • vmaxer
    vmaxer Posts: 5,120
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
    heiney9 Posts: 25,490
    edited June 2015
  • vmaxer
    vmaxer Posts: 5,120
    heiney9 wrote: »
    What ???
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • vmaxer
    vmaxer Posts: 5,120
    edited June 2015
    vmaxer wrote: »
    @telemike did you check these out??
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
    vmaxer wrote: »
    heiney9 wrote: »
    What ???
    Premature posting? H9 just realized we were not talking about TUBES yet! lol
    edited June 2015
    nah,
    I just said don't use bar stools for stands. But someone crafty enough with the right stool could probably make it work. Don't just plop them on the stool and walk away. That would be horrible. But then some of the noobs that post here have horrendous SDA setups. Why bother if you're not going to attempt to do it right to get the best/most from the unusual design.
    SDA and tubes! Go well together!! :)
  • PolkieMan
    PolkieMan Posts: 2,446
    edited June 2015
    That bar stool idea would work if you could find like ones with U shape legs like the stands. http://www.elfurniture.net/modern-bar-stools/modern-bar-stools/
  • telemike
    telemike Posts: 115
    Nah, didn't purse CRS any further. There is a set of RTA11T's for $200 or so nearby
  • My M 7's from '85-86 have one side gone silent. I have had to replace mid's and crossover's over the years, but now all is silence on the left side speaker.
    Any thoughts or suggestions would be appreciated.
    Thanks.
    F1nut Posts: 51,916
    Why was that as it's highly unusual?
    I don't recall if your speakers have fuses on the binding post plate. If so, check those.
