Amp Advice $2000 budget
To be clear the $2000 is the absolute max I am going to be able to go. I really like to stay around $1600ish. This will replacing my current ATI AT1202 powering the RTI12's using the Aventage 1010 as the pre. The 1202 will be moved to surround duty. As of now I am considering:
ATI2002($1790shipped)
Emotiva XPR-2 ($1620 shipped)
Outlaw 7500 5channel($1600shipped)
Used Parasound A21($1300-1600+shipping)
I am really leaning towards the Emotiva for its power advantage and low cost, but matching ATI's would be kinda cool. Thoughts, suggestions?
  • chumlie
    chumlie Posts: 8,658
  • vmaxer
    vmaxer Posts: 5,120
    This.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
    EndersShadow Posts: 17,704
    Parasound, B&K, Sunfire TGA
  • MrBuhl
    MrBuhl Posts: 2,419
    edited June 2015
    Sorry - gonna throw McCormack in there - you could get a DNA-1 Deluxe for that and be very very happy as well! (unless you're only talking new - sorry - didn't consider that)
    Polk SDA1c modded
    Polk SDA2BTL (fully modded)
    SACD Marantz DV8300
    Sony S9000ES CD/DVD/SACD
    Yamaha YP-D6
    Soundcraftsmen PCR800
    Audible Illusions L1 Preamp
    Pho-700 Phono Pre
    tonyb Posts: 33,072
    Of your choices, Parasound then ATI.
    Is there something about the sound you have now you don't like ?
  • Mikey081057
    Mikey081057 Posts: 7,127
    A21
    Garage | Polk Monitor 5B's
  • jeremymarcinko
    jeremymarcinko Posts: 3,785
    tonyb wrote: »
    Not at all, I love the way my 140w ATI sounds, but I think at this point the RTI12's deserve some more power. Although I have never run out of gas with the 1202. I just have an opportunity to upgrade, so... ya know.
  • jeremymarcinko
    I would like to give the parasound a try, I know many of you all enjoy them. I just really prefer to buy new with warranty. Its on the list though and I have inquired on a couple I will see how it all unravels.
    tonyb Posts: 33,072
    Well then, if the ATI tickles your fancy, stick with it and go for the big brother, unless you want to try something different. Parasound mates well with RTI's.
  • jeremymarcinko
    Variety is the spice of life :)
    tonyb Posts: 33,072
    2 black eyes ago, the wife disagreed with that statement.
  • jeremymarcinko
    Do you think the RTI12's will be able to exploit the benefit the A21 brings to the table?
    ^yes
  • Conradicles
    Conradicles Posts: 6,339
    What about new speakers?
  • Mikey081057
    The A21 will drive anything to it's peak potential
  • jeremymarcinko
    Anyone heard anything on the new Emotiva SA-250?
  • hochpt21
    hochpt21 Posts: 5,423
    Find a used B&K 200.5 Reference and spend the rest of your coin on other upgrades.
  • vmaxer
    vmaxer Posts: 5,120
    MrBuhl wrote: »
    Agreed, I don't have the deluxe, but the DNA-1 I recently purchased here is just awesome. The speakers disappear and you have an awesome soundstage.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • Inspector 24
    Inspector 24 Posts: 1,308
    Parasound. But buy my HCA-3500, the design of the Halo series is a direct and very close descendant of the HCA series, all designed by John Curl, and for less than a used A21 you'll get an extra 100wpc and DOUBLE the peak current to add extra oomph and headroom, especially for the low frequencies, and you'll never run out of headroom.
    http://forum.polkaudio.com/discussion/165663/fs-parasound-hca-3500-1400#latest
    Up
    LSi15 LSiC - RX-V3000
    Down
    Sim2 D60 - Dragonfly 106" Panny 500
  • chumlie
    /\ Problem solved /\
  • Inspector 24
    Right? I replaced mine with a fully upgraded Big Sky Audio 3500 unit which some some say brings it awfully close in refinement to the Halo series...maybe even the JC1's but considering the very small difference I've experienced I don't think the RT series are a refined enough speaker to take advantage of higher quality amplification without at least crossover mods.
    However, the difference from the extra power of the 3500 vs the 2003 was very noticeable, treble was smoother more silky, less glassy, certainly not as bright on the high end. I could comfortably listen another 5-10db louder without fatigue after an hour or two, same for my wife.
    And the low end kick it got was awesome, for a lot of things subwoofers are almost unnecessary...almost...they don't drop off steeply until below 30hz, even then if I turn off the subs the average person thinks they're on.
    Up
    Down
  • jeremymarcinko
    The ATI 2002 may be out of contention, unless I can locate another dealer. I was speaking to a fella on the A-gon who sells new ATI's but he started being a little hasty, wanting deposits and telling me the sale ends tonight. Outlaw may be out of stock, will find out for sure tomorrow. Our resident Parasound dealer is working with me too, so a new Halo A21 might be in the cards. I am still considering the used offerings but there is nothing quite like new with a warranty, for me anyway. For some reason I keep drooling over that Emotiva XPR-2 with the 600watts per channel. What a beast.
  • Inspector 24
    I used to worry about warranty, but anything used I've purchased that worked when it arrived never broke, including all five parasound amps, three AVR's, seven subs and three sets of speakers and two projectors I've purchased used over the years. Only things that broke were from abuse or improper packing, which my gear suffers none of. Just sayi'n. ;)
    Up
    Down
  • Polkie2009
    Polkie2009 Posts: 3,834
    +1 that HCA-3500 is a beast!
    msg Posts: 10,452
    edited June 2015
    Is this a combo system or all HT/not much concern for music?
    If not for serious music, and/or if you're not affected or concerned by the common feedback that the Emotiva/RTi combination is bright and harsh, then why wouldn't you go with the XPR-2? 600wpc? Nice. What kind of peak current is that pushing, do you know?
    I would think that to fully realize the benefit of the Parasound A21, you'd want to get new speakers and a separate pre. The A21 would be a terrific anchor piece/2ch investment if you are heading that way. However, if you just want to step into an impactful Parasound, Inspector's HCA-3500 may be a nice opportunity to consider. I just wish he'd do that A/B comparison so we could know what the BSA refresh can do for a 3500. If it's not particularly noticeable, it might help allay any concerns over buying an older amp of this fantastic caliber? and not be overshadowed by the BSA upgrades on the new one? Yes, this is a hint ;)
    My understanding is that the A21 is more refined, but it is less powerful than the 3500. I mean, double the current in the 3500? You can't ignore that. The 3500 should slam the RTi12's. For music, I'd want to try both amps, though. For theater, and barring the opportunity to try them both, I'd probably just want the power and go with that 3500 if I wanted a Parasound, or stick with a fat ATI since you already have one and are pleased with it, or otherwise that Emotiva you're talking about. Something good and crisp and impactful with good control.
    I can also understand/respect the preference for buying new with warranty, but this isn't practical for me at my early level of involvement and penchant for experimentation and trying to get ears on different gear.
    What about matching your gear up, though? Is that not a real concern?
    Personal preference is for Parasound or B&K, in general.
    Now curious about ATI's sound.
  • jeremymarcinko
    I was thinking that the Emotiva's bright sound signature was limited to the xpa line and lower.
    nooshinjohn Posts: 25,912
    Nakamichi PA7, not the MkII... You can also consider pass labs and some Krell at 2k
    msg Posts: 10,452
    oh, is it? could be; I may have picked that up wrong, and have no experience with any of their stuff, unfortunately.
  • dragon1952
    dragon1952 Posts: 4,907
