Bottlehead Crack
1…6791112…15
  • mrbiron
    mrbiron Posts: 5,721
    I just typed this post with my raised tonearm. ;)
    Scomp, you don't skimp on anything you do, do you??
    SCompRacer Posts: 9,404
    edited June 2015
    Thanks! I strive to make diy look and sound as good as I possibly can.
  • agfrost
    agfrost Posts: 2,497
    Well, it worked.
    Jay
  • voltz
    voltz Posts: 5,384
    edited June 2015
    It shows. That TT rules! I can only imagine how nice a Eros will looking next to it.
    I get a Reduction if I didn't like my Vincent PHO8 so much. but I am too happy with it for now!
  • mrbiron
    Second round of staining has been completed. Still do not like the way it is coming out. Maybe a third is needed... :(
    I will start my first coat of Poly this afternoon.
  • ALL212
    ALL212 Posts: 1,690
    The wood is just alder - no grain, no joy. Blumenstein Audio will still make bamboo bases for Bottlehead kits. I believe they've taken them off the website as the sales were so low they didn't want to advertise but I think if you email them you can still get one. Not sure what the cost was...
    Aaron
    Enabler Extraordinaire
    I'm so tired of paint work! Got the wood work farmed out.....farmed, get that pun Aaron? ;)
  • ALL212
    ALL212 Posts: 1,690
    Aaron
  • voltz
    voltz Posts: 5,384
    edited June 2015
    I installed the "SpeedBall" upgrade and my voltage were wrong on term 1 & 7 as they read 165V ...but 2, 4, 9, were fine. and no sound from 1 channel.
    posted on the BH forum and PB guessed correctly on that the R1 resistor had the wrong value if one of my LED's on the 9pin was overly bright.
    so you know the 2 little blue resistor that go to the large PC board and the 2 little blue resistors that go to the small PC boards A & B that all look alike I had a 3.1 ohm in the A instead of the 237 ohm ...just too old and blind as I though i got them correct the first time, I knew all my soldering like fine and could not find a mistake visually until I used my big Magnifying lens.
    Now everything is sounding just fine and I got the new set of tubes from Dan in to put it through its paces today!
  • PSOVLSK
    PSOVLSK Posts: 5,452
    That looks really good. Very impressive!
  • ALL212
    ALL212 Posts: 1,690
    edited June 2015
    voltz wrote: »
    PICTURES!!!!!
    I had to measure them with the VOM...couldn't figure out the stripes at all!! :(
    These are somewhere in the 1/2 a grain of rice size for scale - ok...1/4 size.
    Aaron
  • voltz
    voltz Posts: 5,384
    edited June 2015
    mrbiron wrote: »
    So today is the end of their sale. You can get the Crack ($279) and Speedball upgrade($125) for $299 so i said F-it and ordered one. Do i need it......nope.
    I'm just bored.
    Anyone try one of these things?
    Time to Say thank you Mr.Biron for pushing me into trying this or I never would have gotten the courage to try it myself.
    And thanks to everyone for the help and advise and encouragement along the way. It was fun it was a pain and was nerve wrecking for a bit. but see be done now!
    Only thing left to do now is to get in some Burn-In Time and roll some tubes!
  • voltz
    voltz Posts: 5,384
    a finished pic!
  • ALL212
    ALL212 Posts: 1,690
    did you make your own headphone cable? That appears to be a Furutech plug.
    Aaron
  • voltz
    voltz Posts: 5,384
    It is, but I didn't make it and the other ends say Furutech on them too. I forgot where I got it & how much it cost me.
  • voltz
    voltz Posts: 5,384
    edited June 2015
    here is what they are: iHP-35S
    is terminated with a Furutech 6.3mm stereo connector to Furutech FT-2PS connectors
    Cable length 130cm (4.1ft) and 300cm (9.5ft)
    http://www.adl-av.com/products/cables/headphone/
  • ALL212
    ALL212 Posts: 1,690
    Oh, ya...nice build also! Saw the headphone plug and went "Squirrel!!!" One track mind, two tracks and I'm overloaded!
    Plate is amazing and the color you got out of the base is very nice.
    Did you run the stock cable? IM(not so humble)O - stock cables from Senn, at least the 600's and 650's SUCK!
    Aaron
  • voltz
    voltz Posts: 5,384
    edited June 2015
    Yes, I use the stock cable for a short time and thought they needed replaced badly, I even got some ZY cables
    http://www.amazon.com/gp/product/B00A2QJNJQ?psc=1&redirect=true&ref_=od_aui_detailpages00
    used them for awhile and they are better then the stock cables, but I saw the IHP-35S cables and thought they were worth a shot and that is all I use now.
  • voltz
    voltz Posts: 5,384
    There are running some more specials for the Crack kit...
    Order a Crack kit and you can add a Speedball upgrade for blacker background and better dynamics (regularly $115) for just $20. And we will include a special low noise, matched 5814 tube! $20 Speedball upgrade with Crack order offer ends July 5th. 5814 supply is limited and will be offered thru the 5th or until we run out!
    http://bottlehead.com/?product=crack-otl-headphone-amplifier-kit
  • ALL212
    ALL212 Posts: 1,690
    JUST MAKE THE MADNESS STOP!!!!! :s
    Sold the last one :'( , bought another :# .
    Aaron
  • voltz
    voltz Posts: 5,384
    did you get in on the 6080's sale? or did you just buy them now?
    someday but not today I might consider a Stereomour II or a Seductor + Smash DHT or the monoblocks for full ranger speakers I made...
  • ALL212
    ALL212 Posts: 1,690
    Just now - got the 5814 with the sale.
    I've built the Stereomour I - very nice sound and the II is supposed to be even better.
    Aaron
  • mrbiron
    Hehehe.....let's see who else jumps on board.
    No update on my end besides I hate the box and am going to sand it down and start fresh'er...maybe this weekend with some berrrrrs
  • vcwatkins
    vcwatkins Posts: 1,992
    ALL212 wrote: »
    What speakers have you used with the Stereomour?
  • ALL212
    ALL212 Posts: 1,690
    Dahlquist DQ-10's. Complete rebuild. Super tweet and stock tweet removed, Seas tweeter put in their place. Complete rewire as the input is right at the crossovers now instead of at the base. You won't shake the paint off the walls but it does drive them and drives them very well!
    Aaron
  • vcwatkins
    Wow, would love to hear something like that. Think I may have to try the Stereomour and go from there. Thanks ALL212.
  • voltz
    voltz Posts: 5,384
    edited July 2015
    Can you guess which one is Aaron's ?
  • ALL212
    ALL212 Posts: 1,690
    Mine go "Comando"! B)
    Crossovers:
    Split the woofer/midrange to a different board because of the size of the new components.
    Aaron
    ALL212 wrote: »
    What have they done with Snow White?
    Them nekkid speakers and gear Arron has connected sound darn good!
