Bi-wiring: An interesting article regarding speaker cables
vc69
vc69 Posts: 2,500
edited June 2015 in 2 Channel Audio
Perhaps we can continue this discussion without a thread closure.
Please read this, then discuss (like gentleman?)
http://www.resolutionmag.com/pdfs/DRAGONS/SPEAKE~1.PDF
-Kevin
2 Channel:
Oppo BDP-83 SE
Squeezebox Touch
Muscial Fidelity M1 DAC
VTL 2.5
McIntosh 2205 (refurbed)
B&W 801's
Transparent IC's
Post edited by vc69 on
  • vc69
    vc69 Posts: 2,500
    I don't believe I saw anyone mention the specific reasons bi-wiring is favorable. This article explains it quite well.
    -Kevin
    2 Channel:
    Oppo BDP-83 SE
    Squeezebox Touch
    VTL 2.5
    B&W 801's
    Transparent IC's
    tonyb Posts: 33,072
    For some reason that link isn't working for me. Care to give a short summation ?
    Personally, I've never found I could tell the difference in my system with my ears. Doesn't mean others can't though.
  • vc69
    vc69 Posts: 2,500
    edited June 2015
    Hmm... working for me. It's a PDF. I'll try to attach and upload. Really good stuff in the article, whether you are a "cable guy" or not. Explains the reasons why bi-wiring is a good idea.
    -Kevin
    2 Channel:
    Oppo BDP-83 SE
    Squeezebox Touch
    VTL 2.5
    B&W 801's
    Transparent IC's
  • vc69
    vc69 Posts: 2,500
    How about that, Tony?
    -Kevin
    2 Channel:
    Oppo BDP-83 SE
    Squeezebox Touch
    VTL 2.5
    B&W 801's
    Transparent IC's
  • BlueFox
    BlueFox Posts: 15,251
    Written in 2002. Entire article based on assumptions, no data. Basically, a Roger Russell article. Nothing to discuss in article that hasn't been debunked an infinite number of times in the last decade or so.
  • vc69
    vc69 Posts: 2,500
    edited June 2015
    Fox, did you even read the article?
    I'm afraid nothing much has changed in the last decade or so, however I would direct your attention to WHY bi-wiring is a good idea, and leave the rest if you disagree.
    -Kevin
    2 Channel:
    Oppo BDP-83 SE
    Squeezebox Touch
    VTL 2.5
    B&W 801's
    Transparent IC's
  • BlueFox
    Of course. Otherwise I would not have commented. Did I miss something?
  • kevhed72
    kevhed72 Posts: 5,146
    Summary - The author advocates bi wiring with lawnmower cable over single wiring with audiophile cable. Also, keep your speaker cable runs short as possible.
  • DarqueKnight
    DarqueKnight Posts: 6,765
    vc69 wrote: »
    I discussed it in the other thread, on page 5, but it got buried in the noise.
    BlueFox wrote: »
    Is that the same Roger Russel who railed against high performance audio cables for decades, but when he wanted to sell $18,000 a pair speakers, he wired them up with "audiophile grade" Cardas wire? Then, when he was called a hypocrite, he said he still doesn't believe in audio grade wire, he just did it because he was trying to sell speakers ... to gullible audiophiles.
  • vc69
    vc69 Posts: 2,500
    Missed that somehow.
    Not the same guy, hardly the same nonsense.
    His position regarding wire is common among many audio engineers, however not one I subscribe to.
    The article covered the reasons why bi-wiring is favorable, and what happens between an amp/wire/speakers, in relatively easy to understand terms. I thought that alone was quite useful info for those "reading" and not "participating" in these discussions.
    -Kevin
    2 Channel:
    Oppo BDP-83 SE
    Squeezebox Touch
    VTL 2.5
    B&W 801's
    Transparent IC's
  • Speedskater
    Speedskater Posts: 495
    He could of used a technical editor person. Some things could have been better said. And he got transmission line impedance and end-to-end impedance all mixed up. But the paper is now 13 years old and it is what it is was.
