Free Monitors 12 are they worth fixing or part them out ?
Elinvader
Hi Forum , My friend gave me these pair of Monitors 12 today for free, they are not in great condition but not too damage neither .......They do have 2 frozen drivers and one blown tweeter.....Just want to know are they worth fixing or just part them out .....First time I see this model around....Thanks for the input
Overall these were (are) probably the least loved of the Monitor series. You would not offend too many if you part them out, especially if the cabinets are rough.
Thanks for the reply , well cabinets are like 75% still in good condition , I do owned a pair of Sda 2B's but why say no to a free pair of polkies....I might just part them out....Thanks
Why do these not get much appreciation? Just curious. Is the design too ambitious?I disabled signatures.
The reason the Monitor 7s are considered the sweet spot in the vintage Monitor line, is the single woofer, with a large 10" PR. The Monitor 10s Are similar, but the dual woofers smear the image slightly. Two woofers, side by side, producing the same frequencies, instead of a single point. The Monitor 11s and 12s exacerbate the smearing problem, with even more woofers essentially producing the same frequencies. Some 11s and 12s have acoustical foam behind the outer woofers to alter the frequency response, but the problem remains.Home Theater/2 Channel:
dhsspeakerservice.com/ -
Hi west , west is right I demo them and they sound so boomy , even raise them from the floor , they just don't have that wow factor , I'm going to part them out and sell them in Fleabay and I will take the time to Power Grab the magnets to secure them to fellow polkies out there....Later guys
With 2 frozen drivers and one blown tweeter I'm sure they didn't sound right. I mean, what did you expect!?!Political Correctness'.........defined
President of Club Polk -
The 12s sound great. They need a decent size room to breathe, at least 200 watts/ch( more would be better) and a proper set up ( at least 8 ft apart and away from the back wall around 12" or more) & they will shine. The bass tightens up and they come into focus. They make fantastic fronts for ht also. You can replace those tweeters with the new replacement tweeters(RDO-198) and make them even better. You also need a good clean source for music. They will make good recordings sound better while making bad recordings sound worse. the are the most difficult monitors to work with, but they do sound great if set up properly.- L200 Legends (Black Oak)
- SDA 2B (1989, Oak Tops, 194s, Spikes)
- Monitor 7B (1982 Peerless, Sonicaps, Mills, Binding Posts)
- (2) SVS SB12-NSD (Flat Black)
- SVS SB 3000 (Gloss Black)
- CSi A6 Center (Cherry)
- Pioneer SC-1222K (7.1 AVR)
- Marantz MM 7055 (5 Ch Amp)
- Pioneer PD-D6 SACD Player
- Marantz NR1403 (5.2 AVR)
- Sony UBP-X800M2 (4k Blu-ray)
- Sony UBP-X1100ES (4K Blu-ray)
- Adcom GFA 555 Amp
- Monitor 5 (194s, Side Surrounds)
- Monitor 5Jr+ (194s) {Storage}
- LG OLED65CXPUA (4K OLED TV)
- LG 55UN7300PUF (4K HD TV)
- RT35i (Cherry)
- (2 Pair) RT25i (Cherry)
- CS400 (Center)
- CS350 (Center)
- F/Xi A4 (Rear Surrounds)
- RT25 (Rear Surrounds) {Storage}
- Audioquest Interconnects
- Blu-Jean Speaker Cables & Interconnects
" But boy do I remember the strain of her refrain " LG -
Although ive never seen let alone heard the 12's i can say I have a pair of 11's w/peerless tweets & use them on 50w tube amp. Pure bliss. Keep in mind the inners are in die'n need for updatesRandy-Maine
2ch-RTA15tl crossover upgrade
by David WMG
Yamaha cr1000 cr2040
HT-Yamaha Parasound Acurus
Just curious why raise these ?Hi west , west is right I demo them and they sound so boomy , even raise them from the floor , they just don't have that wow factor , I'm going to part them out and sell them in Fleabay and I will take the time to Power Grab the magnets to secure them to fellow polkies out there....Later guys
Randy-Maine
by David WMG
There is really no comparison of the 11's to the 12's. The 11's have a totally different crossover if I am not mistaken. Making the 11's sound really good compared to the 12's.Since we don’t know where we are going we have to stick together in case someone gets there….Ken Kesey
Idolizing a politician is like believing the stripper REALLY likes you. -
Yes. Being directional & smaller cabinet w/base.Randy-Maine
by David WMG
zip code? I may have interest in them if local.POLK SDA 2.3 TLS BOUGHT NEW IN 1990, Gimpod/Sonic Caps/Mills RDO-198
ONKYO HT RC-360 SONY BDP S590 TECHNICS SL BD-1 -
In my reply to the OP, it was not my intent to bash a Polk product, sorry if it came across as such. I have many vintage Polk's. I heard the Monitor 12's, at a Polk dealer's showroom when they were new, I was not impressed nor were the sales people. I do not have my Polk data files at hand, but I believe the Monitor 12 was only offered in the Monitor Series II line. At this time there was strong competition for the large Monitor 12 with the Polk SDA line and it's CRS+, 2B and 1C were viewed by many at that time as superior sounding, although the 1C's would have cost more than the 12's. I'm sure the 12's can now be made to sound good given the right amplification, sources and space. After the Monitor series ended in the early 90's, the non-SDA RTA 8TL, 11TL and larger 15TL were offered as Polk's replacement for the Monitor's. They used a D'Appolito vertical driver layout, MTM, to improve SQ vs. side-by-side drivers.
If by consensus the 12s do not compare w/ any of the smaller monitors and any SDAs, and since you have a few to many problems I'd also say part them out. I'm heartened to hear 7s are the sweet spot in the vintage Monitor line. I thought 10s were and my newly acquired 7s are sounding great. I have a few question on them on another thread.2chl- Adcom GFA- 555-Onkyo P-3150v pre/amp- JVC-QL-A200 tt- Denon 1940 ci cdp- Adcom GFS-6 -Modded '87 SDA 2Bs - Dynamat Ext.- BH-5- X-Overs VR-3, RDO-194 tweeters, Larry's Rings, Speakon/Neutrik I/C- Cherry stain tops Advent Maestros,Ohm model E
but why say no to a free pair of polkies...Thanks
NEVER say no to free POLKS thats my motto:)
x2. I own a set of these but the 3.1's took their place. I'll keep mine and use them someday.HT/2Channel: Emotiva MMC-1, Adcom GFA-555II, Polk SDA 3.1's, Teac TN-300 TT, Polk Center and Sub.
Bedroom system: Carver CT-24, Parasound HCA-800II, Monitor 10's
Additional projects: RTA 12c's -
With 2 frozen drivers and one blown tweeter I'm sure they didn't sound right. I mean, what did you expect!?![/quote]
Hahahaah F1 I do own a few monitor series I use them for a 7.1 theater so I replace the drivers from my theater rig and gave them a chance to keep them but I just think that listening to my Sda 2b's for a while on my 2 channel sig got me spoiled and really didn't found the sound factor...I tried
I can certainly understand preferring the SDA's. Were the swapped in drivers the exact MWxxxx model? Was the swapped in tweeter a SL2500 or RD0198-1?Political Correctness'.........defined
aprazer402 wrote: »In my reply to the OP, it was not my intent to bash a Polk product, sorry if it came across as such. I have many vintage Polk's. I heard the Monitor 12's, at a Polk dealer's showroom when they were new, I was not impressed nor were the sales people. I do not have my Polk data files at hand, but I believe the Monitor 12 was only offered in the Monitor Series II line. At this time there was strong competition for the large Monitor 12 with the Polk SDA line and it's CRS+, 2B and 1C were viewed by many at that time as superior sounding, although the 1C's would have cost more than the 12's. I'm sure the 12's can now be made to sound good given the right amplification, sources and space. After the Monitor series ended in the early 90's, the non-SDA RTA 8TL, 11TL and larger 15TL were offered as Polk's replacement for the Monitor's. They used a D'Appolito vertical driver layout, MTM, to improve SQ vs. side-by-side drivers.
No intent taken I was just wanted some opinion just to see if the pair was worth keeping and restoring ...I've been in this forum for 5 years now , I don't post or say much I'm a search button guy , but reading through the years I see polkies talk highly on different speakers like Sda line , monitor 11 , 5b , 5jr etc. to keep and not let go , I do own several polks speaker but wanted to see those polkies who own this line , what they think of them.....Thanks -
Same driver model but I used rdo-194 for tweeters ...Would the tweeters change sonic on the speaker ? -
Absolutely, the crossover is not designed for the SL2000/RD0194-1. However, you still may not like them.Political Correctness'.........defined
Ohhhhhh interesting.....Something new I learned today.... I might just part them out and sell them and give fellow polkies a chance to have more drivers for this line.....As of me the funds collected on this part out will give me the funds to get a hold of David so he could TL mod my 2B's
....Thanks F1 for your input and to the other members here ....Polkie for life !!!!! -
I recently sold my set of Monitor 12 series 2 speakers. I thought they were decent speakers but surrounded by my SDA and SRS series speakers they were simply not as good. They were good party speakers. You could certainly rock the house with them but for clarity and performance they were average. I would part them out unless someone donated the drivers and you were not into it much financially. I like my Monitor 7's with peerless tweets much better.Polk HT system 1: LSIC, LSI25 mains, LSI F/X rears, Lsi F/X rear centers,
Yamaha RX-V2500 System, Carver A753 3 channel amp.
Polk HT system 2: , SRT system with f/x 1,000's rear speakers on 7.1 system currently using Onkyo TX-RZ820 receiver, powered by Sunfire Grand Theater amp
Polk Speaker collection: SDA SRS 1.2tl x 2, SRT system, SDA SRS 2 P/B, SDA 2A, SDA 1C Studio, SDA CRS+, Monitor 7B & 4, SRS 3.1tl, RTA 15tl, LS90, LSI 9 -
westmassguy wrote: »Two woofers, side by side, producing the same frequencies, instead of a single point. The Monitor 11s and 12s exacerbate the smearing problem, with even more woofers essentially producing the same frequencies. Some 11s and 12s have acoustical foam behind the outer woofers to alter the frequency response, but the problem remains.
That's why you remove the most offending overlapping frequencies via the crossover, such is the complexity of the RTA-12B and C crossovers.
Also, I was under the impression that the Monitor 11's did this via crossover as well and not just the foam?afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
Village Idiot of Club Polk -
I've not worked on the 11s. We don't have schematics, just rudimentary circuit board sketches for the 11s. It appears and additional Inductor was added to one of the woofers. Not as elaborate as the RTA 12 B/C though.westmassguy wrote: »Two woofers, side by side, producing the same frequencies, instead of a single point. The Monitor 11s and 12s exacerbate the smearing problem, with even more woofers essentially producing the same frequencies. Some 11s and 12s have acoustical foam behind the outer woofers to alter the frequency response, but the problem remains.
ignore spotMaryMitchell wrote: »sweet spot
Town Porch: WiiM Pro Plus * Sunfire Sig II * Canare 4S11 * Magnepan 1.6 * Dectet -
Good loud boomy , Not a "critical listening " speaker. Depends what you want to listen to.if you want clean detailed sound these are not for you! Check the drivers #'s may be hard to find original drivers for parting out.Main Rig:
Nakamichi EC100 Active xover
MIT exp 1 ic's
Perreaux SA33 class A preamp
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable
