New Sony AVRs for music only?
    F1nut Posts: 51,999
    You know, that place where you used the following as your sig. "Of course you can trust your ears. It's brains that are gullible."
  • deronb1
    deronb1 Posts: 5,021
    The new Sonys are nice, but depends on what you are driving. 8 ohm high sensitive bookshelf speakers should do alright, but. If you want full potential out of hungry full range speakers, look elsewhere.
  • vmaxer
    vmaxer Posts: 5,121
    Keiko wrote: »
    Nothing wrong with reliable, budget gear. Amazon was blowing out some Yamaha DVD S1800 universal players a few years back for 80.00. I have one in my main rig, one in the bedroom and one still brand new in storage. They do a nice job at 1080p upconversion and handle redbook and SACDs very well.
    I have a couple as well.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • mrloren
    mrloren Posts: 2,474
    I had Sony for year with just one problem. My 5700ES died after only 2 and 1/2 years. It was still under warranty so Sony sent me a new one. The sound on music is great. The Onkyo 626 I picked up cheap from Amazon sounded great on movies but could not hold music well. I have the new sony back now and rock on. I wish I had the cash for an amp but that will have to wait.
  • felipe
    felipe Posts: 423
    edited June 2015
    I see that my thread has resurfaced..lol. Yes Keiko, I did settle on a reciever..the Sony STR-DN850. Had to go dual-purpose due to SAF. So far it works great :).
    My Setup: Denon AVR X3600h, Polk Signature S50 Fronts w/ S30 Center and S15 Rears, LG UBK90 4K Player, TCL 6-Series 65”4k TV
  • RamZet
    RamZet Posts: 792
    Go to ebay and look up B&K gear and never look back.
    There is a Ref 20 on there for 150.00
    There is a PT3 series2 on there for 199.00
    There is a PT5 on there for 269.00
    B&W CM9Classé Sigma
  • felipe
    felipe Posts: 423
    Rockin steady Keiko ;). Thanks for the input RamZet, when my budget allows I'll give those a look.
