Better Naners: Next project
I am currently using Sewell Dead Bolts and I want to try some better banana plugs. I like the idea of crimping them and hate having to use set screw connections but I want the flexibiltiy so I can put them on other raw cables if and when I change those out. Which ones do you folks like that are not outrageously expensive?
    msg Posts: 10,650
    Sorry, to clarify, are you asking about different "re-usable" banana plugs?
  • afterburnt
    afterburnt Posts: 7,892
  • afterburnt
    Gold on directly on copper.
  • afterburnt
    So you all use outrageously expensive plugs? %^)
    msg Posts: 10,650
    I'm watching this thread, because I'd like to see some suggestions as well. I think someone will come back with a Douglas Connection recommendation for DIY http://douglasconnection.com/
    I don't have much experience here, myself, but would like to build some cables at some point.
  • afterburnt
    I have seen some that are inexpensive copper but wont handle much weight so they would end up getting bent
    msg Posts: 10,650
    Skip, if one were to build, do you know of any good connectors and where to get them?
  • afterburnt
    What is a better connection bananas or spades?
  • ken brydson
    ken brydson Posts: 9,103
    afterburnt wrote: »
    Both about the same IMO, a matter of preference.
  • vmaxer
    vmaxer Posts: 5,124
    edited June 2015
    DSkip wrote: »
    I peruse dougs selection mostly. I do recommend you stay away from those cheap vampire wire spades and bananas though. PNF used them (part of the reason they were so affordable) and they are absolute crap. They don't secure after a few uses and the spades are brittle. Doug reterminated them with some of those copper spades and I love them.
    Which ones did you use, I may do the same with my PNF's ?
    @DSkip
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • Unknown
    edited June 2015
  • afterburnt
  • afterburnt
    I no longer care since I don't know what the hell the other end is made of. Gold on copper, I doubt it.
  • Unknown
  • afterburnt
    I know that Douglas has good stuff but I can't afford to do all of my speakers with those. It seems pretty important to use good terminals but like I said the binding post material is probably brass so doesn't that kind of defeat the purpose?
  • afterburnt
    Resistance?
  • vmaxer
    vmaxer Posts: 5,124
    vmaxer wrote: »
    DSkip wrote: »
    @DSkip
    @DSkip waiting on the answer
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • vmaxer
    vmaxer Posts: 5,124
    Thanks a lot, going to look into changing mine as well.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • afterburnt
    DSkip are those soldered?
  • vmaxer
    vmaxer Posts: 5,124
    edited June 2015
    @DSkip
    Looks like SP8WP48XLNP - can you confirm pease??
    http://www.douglasconnection.com/Furez-SP8-WP48XLNP-Bare-Copper-Spade-Speaker-Connectors-Pair-FZSP8WP48XLNP.htm
    I may go with nanners though, the same material or silver plated, not sure.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • vmaxer
    vmaxer Posts: 5,124
    Aren't the numbers on the sleeves?? I could read almost all of it in your photo??
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • vmaxer
    vmaxer Posts: 5,124
    DSkip wrote: »
    Don't give me that common sense crap. I never looked at the back of them. :p
    Well give it a whirl and report the numbers back. ;)
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • vmaxer
    vmaxer Posts: 5,124
    DSkip wrote: »
    WP30 for biwire speaker ends and WP48XL on amp ends. No wonder I never saw it - that lettering is smaller than it appears on the pics.
    I knew you could do it, thanks a lot!!
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • Upstatemax
    Upstatemax Posts: 2,865
    I've been using the AudioQuest SureGrip100 BFA plugs and I like them a lot.
    They do have set screws, but they hold REALLY well and make an awesome connection.
    Direct Gold or Silver over Beryllium Copper and $40 for an 8 pack.
    I re-termintated my Signal Ultra's in my 2ch system with the Silver versions (did not want spades anymore). I wired my fathers entire new system with the gold versions.
  • afterburnt
    Upstatemax wrote: »
    max who has them?
  • Upstatemax
    afterburnt wrote: »
    max who has them?
    Amazon
  • afterburnt
    I am kinda in limbo now. At least it's affordable lol
    afterburnt wrote: »
    Limbo isn't such a bad place to be, makes you sit back and ponder where to concentrate your efforts....and wallet.
