Better Naners: Next project
I am currently using Sewell Dead Bolts and I want to try some better banana plugs. I like the idea of crimping them and hate having to use set screw connections but I want the flexibiltiy so I can put them on other raw cables if and when I change those out. Which ones do you folks like that are not outrageously expensive?
