comcast remote
hi - I am having no luck syncing my Comcast IR remote - when I press up volume it mutes when I press down the volume goes up
Best Answer
Answers
    tonyb Posts: 33,072
    OleBoot wrote: »
    You're holding it upside down.
    LMAO !!
  • [Deleted User]
    [Deleted User] Posts: 7,658
    Hello,
    Welcome to Polk's forum. I'm assuming you're trying to use your Comcast remote with a Polk soundbar, correct? If so, the Comcast remote is not a good choice to program the speaker. First, place the soundbar in the standby mode (LED is red) then touch the "learn" button until the LED blinks amber. Now the previous instructions have been wiped clean. Now use your TV's remote to program the Polk using the owner's manual's instruction. Once this is done your Comcast remote will control the Polk.
    If you're still having problems contact Polk's CS department at 1-800-377-7655 or via email to: polkcs@polkaudio.com.
    Best regards, Ken
