Bottlehead Crack
1…34689…15
  • voltz
    voltz Posts: 5,384
    I have some Cardas and I think I have more then enough to do the job. also have some Kester I have only used to practice with.
  • mrbiron
    mrbiron Posts: 5,720
    My plates are back with a jet black automotive paint...shiny.
    I'll start marking out the board with a white sharpie and also be sourcing the screws marantz uses on their higher end gear. (Copper colored?)
  • ALL212
    ALL212 Posts: 1,690
    Nice!!
    Kester is good stuff also.
    Copper will look very nice with the black.
    Aaron
    Enabler Extraordinaire
  • voltz
    voltz Posts: 5,384
    Biron is going for some nice style points. Tell you Dad nice job!
    Aaron, where it says to attach a wire from Term 4 to 22L - and adds a revision saying if you hook Term 4 to 14U it maybe quieter and I wondered if you did this?
  • mrbiron
    Thanks Voltz and ALL212.
    Finding copper plated screws is harder than i thought. I am also second guessing the look. The Bottlehead badge is bronze and really won't look right. Maybe i just skip the BH badge?
  • mrbiron
    I'm not also looking at one of these to replace the stock volume pot. Reviews are all over the place. 50 50...some say no improvement at all, some say noticeable. For $28, i may take my chance...
    http://www.ebay.com/itm/Valab-23-Step-Ladder-Type-Attenuator-Potentiometer-100K-Log-Stereo/281714628618?_trksid=p2047675.c100011.m1850&_trkparms=aid=222007&algo=SIC.MBE&ao=1&asc=31356&meid=6fd1353fb1454218804a011aa34afdce&pid=100011&rk=6&rkt=10&sd=301568448140
  • ALL212
    ALL212 Posts: 1,690
    voltz wrote: »
    Yep, sure did but I have no idea if it makes enough difference to hear but what the heck!
    Aaron
  • ALL212
    ALL212 Posts: 1,690
    mrbiron wrote: »
    Should be better than stock but the Blue Alps is about the same cost. Blue Alps is a bit of a pain to wire in. Really small pins. If you've got some $$ stick a Gold Point Stereo pot in there. Wiring is real easy.
    Stock is ok except at low volume and it doesn't balance right down low, one channel always comes up first.
    Aaron
  • ALL212
    ALL212 Posts: 1,690
    mrbiron wrote: »
    If the paint pulled through and you have some on the back make sure you get it scraped off where the ground tab comes through and anywhere else ground points are present. There's been a few builds that the only issue with them was paint covering the back of the plate.
    Beautiful paint job by the way!!
    Aaron
  • mrbiron
    It does look good. The cost of doing business was a 6pack that we polished off yesterday afternoon...so i guess i got him a 3 pack.
    Yeah, he got the back :D ...DOH*
    I'll take a razorblade and clear the areas appropriately. Thanks for the heads up!
    ALL212 wrote: »
    That Gold Point is WAY out of budget! The Japan Alps Type Blue doesn't look to bad in the pin department and is 1/2 the cost of the Valab. Everything i've read says 100K for the attenuator so that is what i've been looking at.
    This build is so far on the back burner that it fell off the stove...
  • voltz
    voltz Posts: 5,384
    Taking my time as I am very green with a soldering iron.
  • ALL212
    ALL212 Posts: 1,690
    Slow and easy - looking good so far! Is that some strange crack pipe up there in the top right corner?
    Aaron
  • voltz
    voltz Posts: 5,384
    LOL its a helping hand with LED light and big magnifying glass.
  • ALL212
    ALL212 Posts: 1,690
    AHH.....clever disguise!!
    Aaron
    mhardy6647 Posts: 35,562
    something -- probably this very thread -- got me looking at the Bottlehead website. That's not a good thing :-P
    So -- they've got a SEP EL84 stereo amp now?!
    And a midprice vacuum tube line-level preamp again?!!
    And a passive network for BSC and HF primping on high-sensitivity and FR speakers?!?!
    How'd I miss all these...?
    You know -- the Crown amp and preamp actually were a little bit of a challenge to find... one day, some years ago now, there was this BIG HEAVY BOX of stuff at the swap pile at the Harvard dump. A quick perusal turned up things like a Nakamichi head demagnetizer, a Watts Dust Bug, cables, odds and ends of an audio nature... and a pair of Crown manuals. But -- something in the box was STILL HEAVY. Way down under the odds and ends -- heh, a D-150 and an IC-150.
    I'd consider free about right for that pair.
  • mrbiron
    edited June 2015
    DSkip wrote: »
    You were too busy digging in the trash to find Crown gear?
    BAZZINGA! - Good one Skip!
    MRH - How are you a good pusher? You peddle their gear and don't even know what they have?!?!?!
    I have an update on the Crack.....I downloaded the manual. That is all! :o
  • ALL212
    ALL212 Posts: 1,690
    I just found another box of small treasure - if you guys burn up a part or need wire let me know. Most of the BH kits I did I did not do stock so I have some extra parts here.
    Aaron
    ... always good to have spare parts handy for... eventualities ;- )
    In all seriousness, a kind offer.
    SCompRacer Posts: 9,408
    edited June 2015
    Crack pipes? Crown vics? Getting wired?
    Ship notice! Bottlehead Eros on the way!
    Nice looking top plate mrbiron!
    txcoastal1 Posts: 13,520
    Hey Voltz come on slacker
    Great job guys
  • ALL212
    ALL212 Posts: 1,690
    SCompRacer wrote: »
    Happy Dancing!!!!
    Aaron
  • ALL212
    ALL212 Posts: 1,690
    I can't sit still... :#
    Added the speedball but rather than put a bunch of cash into the 100uf's output caps I used a pair of Nichicon electro's I had and tipped 'em with a pair of Solen 1.5uf's films I had here. Also tipped the last power supply with a small film cap.
    Just before putting the Speedball in.
    Speedball in zooming!
    Aaron
    edited June 2015
    ALL212 wrote: »
    Nice job!
    Whats the chances of Tom Sawyer-ing you into building the Eros? lol
  • ALL212
    ALL212 Posts: 1,690
    Not hard at all...! But July is gonna suck for spare time, not one Saturday open and at least two Sundays shot.
    Would be fun! (Can I white wash your fence too???)
    Aaron
  • ken brydson
    ken brydson Posts: 9,108
    SCompRacer wrote: »
  • Nightfall
    Nightfall Posts: 10,083
    8MxrvRt.jpg?fb
    afterburnt wrote: »
    Village Idiot of Club Polk
  • ALL212
    ALL212 Posts: 1,690
    SCompRacer wrote: »
    No matter how much bleach I pour in my eyes I can't get that image out....
    OUCH!!
    :D
    Aaron
    edited June 2015
    We need Mikey (Keiko) to cleanse this thread with female intergluteal cleft's, then it will be all fixed...lol
  • voltz
    voltz Posts: 5,384
    The most exciting phrase to hear in science, the one that heralds new discoveries, is not “Eureka!” (I found it!) but “That’s funny …”
    That is what I was saying when I found out my Crack actually works :p
    Not bad for a 1st timer. still I hate soldering especially around 14U after the cap is sitting on top of every $#%^ wire :)
