The Mother And Father Of All Amps!!!
  • Toxis
    Toxis Posts: 5,116
    edited August 2004
    Originally posted by gmorris
    $25,000 per pair. Chump change...
    Do they finance? hahaha YEAH RIGHT!
    *Bank* "So you're looking for a hefty sized loan... what's this going to be used for?
    *Me* "To buy a pair of amplifiers...
    *Bank* *CLICK!!!*
  • I-SIG
    I-SIG Posts: 2,243
    edited August 2004
    Originally posted by scottvamp
    MRA: Master Reference Amplifier. This 600lbs monaural amplifier will give you about 1000watts RMS 8 ohm pure class A. The MRA doubble down to 0,5 ohm and give you 16000watts of clean power. With it’s 16000VA power suppley and 280 Bipolar transistors it will drive anything. Probably even drive the smaller krells in the third picture. And it’s as huge as an ordinary living room table.
    To put it in perspective, a 15000VA power distribution transformer can power several medium-sized houses without too much trouble.
    Wes
    Link: http://polkarmy.com/forums
    Sony 75" Bravia 4K | Polk Audio SDA-SRS's (w/RDO's & Vampire Posts) + SVS PC+ 25-31 | AudioQuest Granite (mids) + BWA Silver (highs) | Cary Audio CAD-200 | Signal Cable Silver Resolution XLR's | Rotel Michi P5 | Signal Cable Silver Resolution XLR's | Cambridge Audio azur 840C--Wadia 170i + iPod jammed w/ lossless audio--Oppo 970 | Pure|AV PF31d
  • I-SIG
    I-SIG Posts: 2,243
    edited August 2004
    Originally posted by tryrrthg
    According to Stereophile :rolleyes: this is the best amplifier EVER!
    The Halcro dm58 monoblock
    It looks like those electro-air filters to me. :rolleyes:
    Wes
  • wlrandall
    wlrandall Posts: 440
    edited August 2004
    Wes
    Not really...your typical newish home with 200A service is 24,000VA/24kVA. Still a helluva lot of juice!
  • I-SIG
    I-SIG Posts: 2,243
    edited August 2004
    Wel, it depends on if the homes are total electric, how far away from the pot they are (for flicker and voltage drop) and how you figure the diversity factor. I had in mind for a medium-sized house right around 1500sq ft. We at the power company size them for the actual load, not necesarily the service size.
    Wes
  • madmax
    madmax Posts: 12,434
    edited August 2004
    Here is a suitable CD transport to go with it.
    http://cls.audiogon.com/cgi-bin/cls.pl?dgtltran&1097674674
    madmax
    Vinyl, the final frontier...
  • scottvamp
    scottvamp Posts: 3,277
    edited August 2004
    madmax
    Or my new Tosh your modding....;)
  • izafar
    izafar Posts: 819
    edited August 2004
    http://cls.audiogon.com/cgi-bin/cls...tran&1097674674
    madmax
    Legendary air bearing transport.... do we need air bearings for a CD player:confused:
    -izafar
    Goldenear Technology Triton 1 - Benchmark AHB2 - Benchmark LA4 - Auralic Vega - Auralic Aries Mini - Marantz TT-15S1 - Clearaudio Nano
  • scottvamp
    edited August 2004
    Does a exotic sports car really need a V12.............;)
  • madmax
    edited August 2004
    You may be surprised how close they would sound to each other. :) But, no, I am using the standard bearings and not replacing your drive with an air bearing. I could spray it with an air compressor before I close it up though. :D (If I ever get the freakin capacitors.)
    madmax
    F1nut Posts: 51,822
    edited August 2004
    Back to the topic at hand, take a look at this display......drool
    F1nut Posts: 51,822
    edited August 2004
    A close up....
  • dcarlson
    dcarlson Posts: 1,740
    edited August 2004
    They look pretty small. :D
    SDA-2a, Anthem Pre-2L, Anthem Amp 1, MF A324 DAC, Rotel RCD1070
    Senn HD650 Cardas, Mapletree Audio Ear+ HD2, Kimber KS1030, Bel Canto DAC2, M-Audio Transit, Laptop.
