Grill posts broken off CS245
I got a nice deal on a CS245 on eBay which arrived today, and it was packed well, but he didn't remove the grill and in transit 3 of the pegs broke off the grill. The 4th one was broken before I bought it.
I am thinking some velcro tabs in the corners. Any other decent ways to fix this? Looks like the grill from my CS175i will fit it, but then I still need to fix it on the CS175i which I am donating to my daughter with some RT25i's.
  • ken brydson
    ken brydson Posts: 9,011
    I remember a thread long time ago. Small drill bit into grill positions for the pegs. Insert short lengths of paperclips into the grill holes and superglue. Then drill the same size hole into the broken pins and superglue them on to the paperclip wire. Supposed to be stronger that the originals.
  • Jimbo18
    Jimbo18 Posts: 2,351
    Okay, thanks for the suggestion, Ken.
  • chefkungfu
    chefkungfu Posts: 636
    I did the same thing for 2 of my SRT's grills, but I used a metal coat hanger. It was a heavier gauge and much harder to cut, but the end result was really good. Either way is still better than the original pegs. Excellent way to repair the pegs.
    SRT Seismic System with dual PSW1200's
    RT5000 x 2
    RT2000p
    CS400i
    CS350-LS
    LS F/X
    PSW650
    PSW1000 w/Dayton SPA1000
    DSW MicroPro 4000
    Adcom amps
    Pioneer Elite SC-89
    Pioneer PLX-1000 Turntable
    PS4
    XBOX One
    MIT Interconnects
    BJC
