Grill posts broken off CS245
Jimbo18
I got a nice deal on a CS245 on eBay which arrived today, and it was packed well, but he didn't remove the grill and in transit 3 of the pegs broke off the grill. The 4th one was broken before I bought it.
I am thinking some velcro tabs in the corners. Any other decent ways to fix this? Looks like the grill from my CS175i will fit it, but then I still need to fix it on the CS175i which I am donating to my daughter with some RT25i's.
I remember a thread long time ago. Small drill bit into grill positions for the pegs. Insert short lengths of paperclips into the grill holes and superglue. Then drill the same size hole into the broken pins and superglue them on to the paperclip wire. Supposed to be stronger that the originals.
Okay, thanks for the suggestion, Ken.
ken brydson wrote: »I remember a thread long time ago. Small drill bit into grill positions for the pegs. Insert short lengths of paperclips into the grill holes and superglue. Then drill the same size hole into the broken pins and superglue them on to the paperclip wire. Supposed to be stronger that the originals.
I did the same thing for 2 of my SRT's grills, but I used a metal coat hanger. It was a heavier gauge and much harder to cut, but the end result was really good. Either way is still better than the original pegs. Excellent way to repair the pegs.SRT Seismic System with dual PSW1200's
RT5000 x 2
RT2000p
CS400i
CS350-LS
LS F/X
PSW650
PSW1000 w/Dayton SPA1000
DSW MicroPro 4000
Adcom amps
Pioneer Elite SC-89
Pioneer PLX-1000 Turntable
PS4
XBOX One
MIT Interconnects
BJC
