Attenuating component tweeters
So, this is probably a little premature, but I've read that some of the Focal component tweeters run a little harsh. Is this issue best solved by just using EQ or by adding an attenuator at the tweeter? I like the idea of cutting down the highs a bit at the source and then EQing only when necessary.
TV: 65" Samsung QLED 4K
AIYIMA Tube T7 preamp --- Nobsound 12AX7 tube preamplifier
