spiking on hard wood floors
    SCompRacer Posts: 9,128
    txcoastal1 wrote: »
    My spikes are under my rack to give enough lift for my small pallet jacket. Pallet jack makes it easier to swap cables and gear. It also isolates turntable from vibration.
    Now that's hard core, pallet jack your rack. ;)
    txcoastal1 Posts: 13,519
    edited May 2015
    I like my rack, and my wife likes my rig ;)
    But seriously I use a mini pallet jack to move the rig
  • leftwinger57
    leftwinger57 Posts: 2,917
    Since those composite blocks that I got for free will not do anything to pass the isolation test I think again when I'm in lifting shape to do the spikes on pavers, which I do have. Oh, my 2Bs are dead level center on the bubble. Adding the pavers and spikes might need some adjusting, hopefully not.
  • lawdogg
    lawdogg Posts: 469
    SCompRacer wrote: »
    lawdogg wrote: »
    I'm a little confused about spikes with bases that have felt pads underneath. Why not just put the felt pads on the speakers and skip the spikes altogether?
    If only all floors were level.... Think about it, sometimes you have to adjust the spikes to get both speakers on the level and on the square.
    I dunno, if I had to do that maybe I'd just use 2 pads on one corner!
    SCompRacer wrote: »
    And spikes are kewl.
    Seeing some of the spikes posted above, I'd agree wholeheartedly! They look like something Batman might carry in his utility belt!
    <3 my 3.1TLs
    I will fix your shifted magnets for free. :)
    edited May 2015
    lawdogg wrote: »
    Two could be 'too' many...might have to split it in half. A half pad.... lol
    Some of us just like to screw around.....
  • machone
    machone Posts: 1,566
    My floor is thin carpet over concrete. To move my speakers around I tilt them onto one spike, rotate the speaker and set it down on another spike and rotate again walking the speaker across the room. With two people it may be possible to walk the speaker into position using the composite blocks under the spikes to protect the floor until you get close then tilt the speaker to remove the blocks. My floor required adjustable spikes for leveling and stabilizing. Once set up they are rock solid. A pallet jack would be the ultimate.
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
  • nspindel
    nspindel Posts: 5,343
    You'll snap a spike if you do it that way, and probably end up with the threaded end stuck in the speaker.
    This discussion reminds me why I love my CRS+'s so much. Speakers on stands, stands on spikes!
  • machone
    Yes, depending on the design of the spike it may snap. The spike design that I use has not given me any problems and unless abused will not bend or break.
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
  • leftwinger57
    I'll agree the mini pallet jack is one smart thing to have. I on the other hand for my former rack I made a rolling platform out of 1" ply and casters. Of course I painted it w/ my world famous flat black from H.D. and it worked great to get at the rear to rewire. My black behemoth now has it's own casters so I retired the platform until I see a 5 shelf glass rack.
