Turntable cartridge alignment
muncybob
I took my tt to a local dealer to have the cart set up. I was going to do this myself but since I don't plan on swapping out carts I figure for the small amount he was to charge why buy the protractor and scale. To my surprise he didn't use a protractor but had an old "album" from MoFi called a Geo Disc. I had already printed out one of the online tools to use and got the cart in the ball park and he hardly made any adjustment from there although the weight was better calibrated using the scale. I just don;t see how the Geo Disc can be as accurate as a protractor as it relies on line of sight to the pivot point and even being off just a fraction there changes things. Anybody ever use one of these?
Yep, my name really is Bob.
Those work pretty well..MFSL came out with them better than 20 years ago..follow the instruction on the disc and you will do fine with it...still better to use a tracking force scale to set proper weight...
Yea, he used a digital scale. Time now to decide how to clean my neglected records.Yep, my name really is Bob.
Parasound HCA1500A(indoor sound) and HCA1000(outdoor sound), Dynaco PAS4, Denon DP1200 w/Shure V15 Type V and Jico SAS stylus, Marantz UD7007, Polk L600, Rythmik L12 sub. -
Paint brush, dish soap, sink with 1/2 inch warm water. Keep the water off the label. i do this for everyday records and it works great. Put them in the dish rack once rinsed off and towel dry with soft cloth.
I am ocd and use a usb microscope, custom made tractor, test record, fozgo meter and digital scale. Even though my ears are my final instrument it removes doubts.Speakers: SDA-1C (most all the goodies)
Just get a vacuum rcm.
Best vinyl investment you'll make.2 ChannelTurntable - VPI Classic 2/Ortofon 2M BlueAmplification - Rogue Audio Cronus Magnum II, Parks Audio Budgie PhonoSpeakers - GoldenEar Triton 17.2 Home TheaterDenon AVR-X3300W; Rotel RMB-1066; Klipsch RP-280F's, Klipsch RP-450C, Polk FXi3's, Polk RC60i; Dual SVS PB 2000's; BenQ HT2050; Elite Screens 120"Man CaveTurntable - Pro-Ject 2.9 Wood/Grado GoldAmplification - Dared SL2000a, McCormack DNA 0.5 DeluxeCD: Cambridge AudioSpeakers - Wharfedale Linton 85th Anniversary; LSiM 703; SDA 2A -
Spin Clean if you have less than 200. I got a Vp-16 now, but only cause I won it.
ONKYO HT RC-360 SONY BDP S590 TECHNICS SL BD-1 -
The MFSL Geo-Disc works amazingly well to set up a cartridge! You just cannot over-think it.DKG999
Music System: Magnepan 1.6QR, SVS SB12+, ARC pre, Parasound HCA1500 vertically bi-amped, Jolida CDP, Pro-Ject RM5.1SE TT, Pro-Ject TubeBox SE phono pre, SBT, PS Audio DLIII DAC -
Our eyes can do line of sight pretty good.
The Geo-Disc is a great tool. Most protractors don't have the reference line to use line of sight to eyeball center of arm pivot. The best protractors to download will have a scale to measure to ensure they printed to the correct size. Most important thing is using the proper protractor for your table. The two most popular methods are Baerwald and Stevenson. Just different math to reduce IGD (inner groove distortion) as the tonearm gets to the inner tracks.
I use a HiFi News Test LP that is supplied with protractor. It offers 3 different alignment techniques to use.
I still have a first gen Feickert alignment tool which had a point to center above the arm pivot. It came in handy for all the tables I tried that never seemed to have the protractor included.
Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
I have a Geo Disc, it is included with the MFSL Sinatra box set that I own. Quite frankly I found the directions a bit confusing and have not tried it. Anyone know if there's a video out there somewhere demonstrating how to use it? I tried looking for one and couldn't find anything.Good music, a good source, and good power can make SDA's sing. Tubes make them dance.
not sure but doesn't "21st century Vinyl" Michael Fermers Practical guide to turntable setup so how to use it?2 ch- Polk CRS+ * Vincent SA-31MK Preamp * Vincent Sp-331 Amp * Marantz SA8005 SACD * Project Xperience Classic TT * Sumiko Blue Point #2 MC cartridge
I don't know a thing about aligning a cart but I do use the Dawn warm water treatment for really filthy garage sale LPs. Instead of rack drying I set them up for a fan to blow them dry. It does work. Finding scratch free LPs is fairly easy but pops and crackles not so much.2chl- Adcom GFA- 555-Onkyo P-3150v pre/amp- JVC-QL-A200 tt- Denon 1940 ci cdp- Adcom GFS-6 -Modded '87 SDA 2Bs - Dynamat Ext.- BH-5- X-Overs VR-3, RDO-194 tweeters, Larry's Rings, Speakon/Neutrik I/C- Cherry stain tops Advent Maestros,Ohm model E
Actually I gave the directions another read on the Geo Disc and used it to check my cartridge alignment, it's pretty straightforward. And my cartridge is perfect!Good music, a good source, and good power can make SDA's sing. Tubes make them dance.
I use my VPI 16.5 RCM to suck dry the records I have run through my Spin Clean. I've got super quiet vinyl now, best method I have tried yet to reduce the ticks/pops.DKG999
http://www.vinylengine.com/tools.shtml has some great info and tools for alignment. I had used one called "Arc Template Generator" to create custom templates for my TTs. I carefully scaled them for my laser printer then finally printed them on clear plastic viewfoils. I used the Löfgren A (Baerwald) alignment and wit very good results.Stan
Main 2ch:
HT:
Other stuff:
