Turntable cartridge alignment
I took my tt to a local dealer to have the cart set up. I was going to do this myself but since I don't plan on swapping out carts I figure for the small amount he was to charge why buy the protractor and scale. To my surprise he didn't use a protractor but had an old "album" from MoFi called a Geo Disc. I had already printed out one of the online tools to use and got the cart in the ball park and he hardly made any adjustment from there although the weight was better calibrated using the scale. I just don;t see how the Geo Disc can be as accurate as a protractor as it relies on line of sight to the pivot point and even being off just a fraction there changes things. Anybody ever use one of these?
Yep, my name really is Bob.
  • Msabot1
    Msabot1 Posts: 2,098
    Those work pretty well..MFSL came out with them better than 20 years ago..follow the instruction on the disc and you will do fine with it...still better to use a tracking force scale to set proper weight...
  • muncybob
    muncybob Posts: 3,267
    Yea, he used a digital scale. Time now to decide how to clean my neglected records.
  • gfong
    gfong Posts: 1,079
    Paint brush, dish soap, sink with 1/2 inch warm water. Keep the water off the label. i do this for everyday records and it works great. Put them in the dish rack once rinsed off and towel dry with soft cloth.
  • thsmith
    thsmith Posts: 6,082
    edited April 2015
    I am ocd and use a usb microscope, custom made tractor, test record, fozgo meter and digital scale. Even though my ears are my final instrument it removes doubts.
  • hochpt21
    hochpt21 Posts: 5,423
    Just get a vacuum rcm.
    Best vinyl investment you'll make.
  • PolkieMan
    PolkieMan Posts: 2,446
    Spin Clean if you have less than 200. I got a Vp-16 now, but only cause I won it. :)
  • dkg999
    dkg999 Posts: 5,647
    The MFSL Geo-Disc works amazingly well to set up a cartridge! You just cannot over-think it.
    DKG999
    SCompRacer Posts: 9,128
    edited May 2015
    Our eyes can do line of sight pretty good. ;) The Geo-Disc is a great tool. Most protractors don't have the reference line to use line of sight to eyeball center of arm pivot. The best protractors to download will have a scale to measure to ensure they printed to the correct size. Most important thing is using the proper protractor for your table. The two most popular methods are Baerwald and Stevenson. Just different math to reduce IGD (inner groove distortion) as the tonearm gets to the inner tracks.
    I use a HiFi News Test LP that is supplied with protractor. It offers 3 different alignment techniques to use.
    I still have a first gen Feickert alignment tool which had a point to center above the arm pivot. It came in handy for all the tables I tried that never seemed to have the protractor included.
  • nspindel
    nspindel Posts: 5,343
    I have a Geo Disc, it is included with the MFSL Sinatra box set that I own. Quite frankly I found the directions a bit confusing and have not tried it. Anyone know if there's a video out there somewhere demonstrating how to use it? I tried looking for one and couldn't find anything.
  • voltz
    voltz Posts: 5,384
    not sure but doesn't "21st century Vinyl" Michael Fermers Practical guide to turntable setup so how to use it?
  • leftwinger57
    leftwinger57 Posts: 2,917
    I don't know a thing about aligning a cart but I do use the Dawn warm water treatment for really filthy garage sale LPs. Instead of rack drying I set them up for a fan to blow them dry. It does work. Finding scratch free LPs is fairly easy but pops and crackles not so much.
  • nspindel
    Actually I gave the directions another read on the Geo Disc and used it to check my cartridge alignment, it's pretty straightforward. And my cartridge is perfect!
  • dkg999
    dkg999 Posts: 5,647
    I use my VPI 16.5 RCM to suck dry the records I have run through my Spin Clean. I've got super quiet vinyl now, best method I have tried yet to reduce the ticks/pops.
    DKG999
  • skrol
    skrol Posts: 3,466
    http://www.vinylengine.com/tools.shtml has some great info and tools for alignment. I had used one called "Arc Template Generator" to create custom templates for my TTs. I carefully scaled them for my laser printer then finally printed them on clear plastic viewfoils. I used the Löfgren A (Baerwald) alignment and wit very good results.
    Stan
    Main 2ch:
    HT:
    Other stuff:
