DAC & CDP Testing
kevhed72
I have long suspected my DAC and CDP may not be the best match for my system.
CDP is a Cambridge 640 v2 and the DAC is a Music Hall 25.3 which has one tube in it.
I am running 703s with a seperate sub, and many of my CDs just dont seem to have the 3D imaging thing happening compared to HD radio or my old school tuner. Furthermore, I was switching back and forth between the Cambridge internal DAC and the Music Hall....and frankly there is no clear cut "better" sound....only nuanced differences.
So I throw out to the forum...what gear goes, what stays....due I have a ton of music on CD.
what tube are you running in the 25.3?
It is a hard call since you have a lot on cd. Maybe just sell both and get Marantz SA8005 and call it a day.Klipsch The Nines, Audioquest Thunderbird Interconnect, Innuos Zen MK3 W4S recovery, Revolution Audio Labs USB & Ethernet, Border Patrol SE-I, Audioquest Niagara 5000 & Thunder, Cullen Crossover II PC's. -
What cables is being used between it all ?
CDP and a dac ? Gotta have a budget in mind or it's going to be all over the place.HT SYSTEM-
lsi 9's -
The CA should make a fine transport. I would upgrade your DAC. Running a sub a little too hot can sometimes collapse your soundstage due to too much muddiness. How did you calibrate the sub? Have you tried lowering the subs output a notch or 2?Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
digital coax is an AQ vdm 3What cables is being used between it all ?
from the DAC to integrated I have tried AQ Diamondbacks and King Cobras.
As far a budget goes, I would be willing to get something that plays standard CDs and SACDs for say....a grand new or used?
OR sell my current DAC for a new one...for 500ish.
speaker placement could also be an issue.Amplifiers: Norma IPA 140, MasterSound Compact 845, Ayre v6xe, Consonance Cyber 800
Puritan PSM156 -
My buddy did drop off a Rotel 1072 cdp yesterday to get a better idea of whats what....plan to give it a workout this weekend
Since you like the more fleshy tone of your tuner, I'm thinking the Cary Xciter dac or the Teac dacs. More of an analog sound with some great soundstaging.
The Marantz SACD players are pretty darn good for the price. Gonna be hard to beat for a SACD player under a g note....imho anyway.
The Diamondbacks and King Cobra's aren't helping any either for soundstaging and fleshed out tone. Throw some MIT's shotguns in there, and be prepared to go looking for your left nut.....if the cat hasn't grabbed it from under the couch. Not to worry though, he'll cough it up later.HT SYSTEM-
lsi 9's -
Agree, the diamondback and King cobra sound quite "dry" and 2-dimensional to me. I much preferred sidewinder/copperhead--though supposedly "lower end."Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
Thus far, the Rotel 1072 sounds better all around compared to my current gear. Thanks for the info. on the cables....honestly it would have been the last place I would have looked, or listened. Tony, which TEAC DAC would you start with....there seems to be many models...I dont need anything with a pre amp in it.
TEAC has some rebates going on so goto their main site and check if you do get one of theirs DAC's
http://audio.teac.com/news/display/965/
http://www.crutchfield.com/p_063UD301/TEAC-UD-301-Black.html?tp=593402 ch- Polk CRS+ * Vincent SA-31MK Preamp * Vincent Sp-331 Amp * Marantz SA8005 SACD * Project Xperience Classic TT * Sumiko Blue Point #2 MC cartridge
This may be the ticket......thanksTEAC has some rebates going on so goto their main site and check if you do get one of theirs DAC's
http://www.amazon.com/Teac-Monaural-Converter-Streaming-UD-501-B/dp/B00BC1ULTQ -
I almost bought the Teac 501, but Ibought the Marantz SA8005 SACD instead and use it for my DAC and started buying some SACD's. now looking back and after what other have said I wish I'd just bought the TEAC and went to using a player for Hi-rez audio files and ....
cause I found several songs that really rock on my system but they are all on different CD's, but if I had a file player setup using the TEAC I could make some kick $$$ playlist! ...Now I still can do this with my Marantz using my PC or Laptop and Jriver Media to play them but...2 ch- Polk CRS+ * Vincent SA-31MK Preamp * Vincent Sp-331 Amp * Marantz SA8005 SACD * Project Xperience Classic TT * Sumiko Blue Point #2 MC cartridge
Your gonna have to step up your DAC game pretty high to out do that Rotel, IMO.
Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2 -
I dunno Steve, I've seen Benchmark dac1's going for 6 bones.....imho, that's a step up.
I'd look for a spinner with a digital input that way you have your computer music covered also. You could also step up to a used OPPO 105, and cover all bases plus video and 4k if you ever go there.HT SYSTEM-
lsi 9's -
It really puts the Cambridge to shame....if I could scoop one up in good condition for a fair price, I'd snag it in a heartbeat. To my ears, it does my 703s more justice than my buddys Martin Logans.That Rotel is a very highly rated cdp.
I forgot at the start you did mention you had tons of CD's, so you may want to add a spinner like Tony said. unless you rip everything with your PC, and got that route. but I like having both options.2 ch- Polk CRS+ * Vincent SA-31MK Preamp * Vincent Sp-331 Amp * Marantz SA8005 SACD * Project Xperience Classic TT * Sumiko Blue Point #2 MC cartridge
