SDA-2ATL Project
westmassguy
This was an interesting project. The 2As are 3rd generation, and have a split Crossover. The Stereo Sections were rebuilt with Sonicaps, Mills Resistors, and new Insulating Binding Posts. The TL Modification was done per the CRS+/2B method.
The Dimensional Section was rebuilt using Sonicaps for the Shunts, and Dayton 5% MP Caps for the Sub-Bass Drive Circuits. The existing Spool Inductors were discarded, and New Erse SuperQs installed in their place. All Caps were secured with 3M VHB Tape, and Nylon Wire Ties. The ONLY time I use Hot Glue, is to seal the back of the Binding Posts. Cardas Quad Eutectic Solder was used exclusively.
To consolidate everything and make it easier to install, New Mounting Boards were fabricated from 1/2" MDF, with 1/4-20 Hurricane Nuts and shorter Hex-Head Cap Screws.
The original Circuit Board, New Sub-Bass Drive Caps and Inductors were all mounted to the new boards. To prevent movement and possible rattling or vibrations, highly compressible foam gasket material was installed on the back side of the boards, near the ends.
To complete the rebuild, a new Interconnect Cable was fabricated from Canare 4S11 "Star Quad", with SpeakON Plugs and Sockets. Matching Speaker Cables were made with the same Canare 4S11, and locking Banana Plugs finished them off.
Home Theater/2 Channel:
dhsspeakerservice.com/
Post edited by westmassguy on
Nice work Dave. Very well laid out."Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer
Thank You Sir.Home Theater/2 Channel:
dhsspeakerservice.com/ -
I gotta save my shekels for new X's for my 2a's.
Looks good, Dave.2 ChannelTurntable - VPI Classic 2/Ortofon 2M BlueAmplification - Rogue Audio Cronus Magnum II, Parks Audio Budgie PhonoSpeakers - GoldenEar Triton 17.2 Home TheaterDenon AVR-X3300W; Rotel RMB-1066; Klipsch RP-280F's, Klipsch RP-450C, Polk FXi3's, Polk RC60i; Dual SVS PB 2000's; BenQ HT2050; Elite Screens 120"Man CaveTurntable - Pro-Ject 2.9 Wood/Grado GoldAmplification - Dared SL2000a, McCormack DNA 0.5 DeluxeCD: Cambridge AudioSpeakers - Wharfedale Linton 85th Anniversary; LSiM 703; SDA 2A -
ThanksHome Theater/2 Channel:
Very nice work, as usual, Dave! Great documentation (pics and write-up) too.
Well done!
Looks good Dave. Are they yours or a customers?
Thanks fellas.Home Theater/2 Channel:
I've done everything conceivable to mine, except for the veneer. All the internals were finished last year.Looks good Dave. Are they yours or a customers?Home Theater/2 Channel:
Very impressive and done perfectly Dave.POLK SDA 2.3 TLS BOUGHT NEW IN 1990, Gimpod/Sonic Caps/Mills RDO-198
ONKYO HT RC-360 SONY BDP S590 TECHNICS SL BD-1 -
Thank You SirHome Theater/2 Channel:
Looks good David. Nice & CleanRandy-Maine
2ch-RTA15tl crossover upgrade
by David WMG
Yamaha cr1000 cr2040
HT-Yamaha Parasound Acurus
Kind of a stupid question. But when you do all this to the crossovers do you replace all the wires that go to the woofers & tweeters ?Randy-Maine
by David WMG
Excellent work again Brother
Thank you guys.Home Theater/2 Channel:
boston1450 wrote: »Kind of a stupid question. But when you do all this to the crossovers do you replace all the wires that go to the woofers & tweeters ?
Certain wires I replace, but mostly cut back and re-solder all the connections, as they're usually frayed a bitHome Theater/2 Channel:
