Tube help needed.
I sent the below to a few members via PM, but in hindsight perhaps I should have potsed for greater visibility:
Need some advice/tube wisdom. I'm trying out some used preamps and the one that sounds decent and is in my price range is the Dynaco PAS-4 although I have yet to try out the phono. I actually think it's a very close second to the CJ PV2 that I am also auditioning, but that one is a bit out of our budget right now. The PAS-4 manual states it originally came with 12AX7(ECC83) line? and 6DJ8(6922) for I believe the phono stage? I opened up the unit and it has Tungsol 1207 and for phono Sylvania 34167, 82219, 6DJB and one that has no markings at all. If I were to keep this unit what would you suggest for tube changes, if any? From what I have read these preamps usually had a 6922 in it and suggested tube would have been 6N1P?
Yep, my name really is Bob.
  • muncybob
    muncybob Posts: 3,263
    OK, I just read the manual a little more and now realize the line stage tubes are the 82219 and the unmarked tube, the other 4 are the phono.
  • marvda1
    marvda1 Posts: 4,962
    Puritan PSM156
    mhardy6647 Posts: 35,208
    edited April 2015
    Heh -- I've never seen a PAS-4. Looks like it was Panor-era "Dynaco"? At any rate, nice looking piece of hardware; looks like it is chock-full of WIMA caps (not a bad thing at all). The only thing I see that I don't particularly care for is putting everything on one big PCB.
    Schematic at:
    http://dynacotubeaudio.forumotion.com/t1400-dynaco-pas-4-schematics-now-added-to-the-schematic-sticky-above (from Bob Latino)
    Mo' info at:
    http://www.audiokarma.org/forums/showthread.php?t=56175
    So -- I'm sorry, what's the question? Are you asking about 6DJ8/6922 subs, or whether a 6N1P can be back substituted for a 6922? If the latter, I think that the filament current draw of the 6N1P is higher than a 6922 (i.e., the latter can sub for the former, but not vice versa -- I think...).
    EDIT: Ok -- I registered at the Dynaco forum (which I'd never seen before today...) and downloaded the schematics. V1 and V4 are 12AX7; the other four tubes are 6922. The 12AX7s are used as the MM phono preamp tubes (just as in the earlier, "real" Dynaco PAS-2/PAS-3 preamps). Generically, I'd suggest either a pair of 5751s to replace the 12AX7s -- or (if there's enough gelt in the ol' piggybank) a pair of gen-u-ine Amperex or Telefunken ECC83s. I believe the 5751 has a little less gain (amplification factor) than a 12AX7, so they might not be the best choice for a phono preamp.
    For the 6922s... well, the canonical choice would be four Amperex 7308 tubes... but they, too, are 'spensive.
  • muncybob
    I'm a complete newbie when it comes to tubes. Heck, I just learned the right way to take them out! I don't understand how you know what tubes will work in a piece. I listed what's in there now to see if anybody feels they could/should be swapped out for somethng else. At this price point($400) I'm not sure I could do much better on a tubed pre w/phono? I am a bit nervous about buying something this aged though.
  • marvda1
    start with something new that a few members know about like this dared.
    http://www.audiocircle.com/index.php?topic=134018.msg1422250#msg1422250
    you can learn with this pre just add a phono pre.
    Puritan PSM156
  • Faustin
    Faustin Posts: 1,151
    I have been very happy with my Dared pre. It was my first dive into tubes.
  • voltz
    voltz Posts: 5,384
    I loved the time I spent using Paul's Dared preamp, I do think you would like it as your pre Bob! and most of them have a remote. and finding one at 300 is a nice price and leaves money for a phono amp maybe enough for a "Bugle 2" phono amp? and several here can help with the tubes for it.
  • dkfreebird
    dkfreebird Posts: 1,186
    I have had the Dared for a few weeks now and love it.It is my first tube piece and you will not regret getting one.The list of different tubes you can use in it can be found here on the forum and then you can find what suits your taste from there.
    Polk 1.2tl's Modded with dreadnought
    Musical Fidelity M6Si
    North Star Intenso Dac
    Auralic Aries Mini Streamer
    Oppo 103
    Pangea PC
    Wireworld Equinox 7 interconnects
    Wireworld Equinox 7 Speaker Cables and Jumpers
    Backups 2.3tl, Crs+ pin/blade with stands.Monitor 5&7 peerless,Polk R200,Usher CP6311.McCormack Dna 0.5 Deluxe McCormack Dna 1,Dared Sl 2000A,Dayens Ampino,Rogue Magnum 66 pre
  • muncybob
    Decisions, decisions...this is worse than picking out paint colors when remodeling! I wish the dealer had one for me to try out. I guess I culdn't go wrong though as it seems from the above comments I could easily recover my $$ on a re-sell.
