best ways/device to listen to music wireless
  • Simplyrandom
    Each of these options have their pros and cons as to your original post. The Hapurs or the Sound mate gives you the flexibility you were seeking. It can function through your router or as a stand alone wireless solution. You could stream audio from your pc using Jriver or one of the other media solutions or one of your guests could connect to it directly and stream media from their own device. The one drawback to that would be they would possibly need to install the appropriate app to connect to the device. I like the simplicity of it and the fact that it is not Bluetooth which is in my experience can be a bit temper mental at times. The one other issue would be you have to use the internal DAC with the device which I read you prefer not to do. I do not know what your current Dac is.
  • jeremymarcinko
    jeremymarcinko Posts: 3,785
    Actually, the hapurs/soundmate also has an optical/spdif output in addition to the analog out. He could use his dac assuming the dac will accommodate an optical cable. This is how I am using mine. Optical connection from the hapurs to my integrated.66h59wtrh8o5.jpg
  • damnusernames
    This is frustrating, the hapurs seem like a good idea, it is cheap and does pretty much what I need it to do...
    But I can't find it anywhere in canada!!
  • damnusernames
    Thank you for this breakdown of the info. I am trying to find hapurs in canada....hapurs does not list any retaillers for canada and amazon.com does not ship outside usa...
  • jeremymarcinko
    This seems to be the same thing and available in Canada. Keep in mind you will likely still need to install DLNA rendering software on your pc. Jriver, airfoil, media monkey, to name a few. These are relatively cheap, jriver is my choice for local files, but airfoil works great for sending, spotify, Pandora, I heart, etc. over DLNA, which jriver doesn't do at this point.
    http://www.amazon.ca/gp/aw/d/B00V4I0IKO/ref=mp_s_a_1_2?qid=1428511470&sr=8-2&keywords=soundmate+m2&dpPl=1&dpID=41dApLFMRHL&ref=plSrch&pi=SY200_QL40
  • damnusernames
    interesting, thank you!!!
  • erniejade
    erniejade Posts: 6,315
    would iscsi mapped as a drive work on a laptop using jriver so DLNA would not be needed?
  • damnusernames
    damnusernames Posts: 84
    edited April 2015
    Could one plug a laptop (cheap with external hard drive) in the DAC and control that laptop wirelessly? From other devices?
  • Mikey081057
    Mikey081057 Posts: 7,127
    edited April 2015
    I use audioengine B1 streaming Tidal BT HI FI from my mobile device to my Marantz AV7701 in stereo to my 705s indoors and out from my AV7701 to my Yaqin MC100B to drive my outdoor Atrium 8's.
    Garage | Polk Monitor 5B's
  • damnusernames
    So Source-bluetooth-dac-amp-speakers ??
  • erniejade
    damnusernames, yes. Right now I am using jriver with a usb drive into my laptop going into the dac. I can control it with the laptop or gizmo via my cell.
    Soon as I have time, I am going to see if the iscsi part on the nas would work since the laptop would or should see it as a "drive" and just point jriver to it. In theory i think it should.
  • Mikey081057
    Yes... 2 amps though... one indoors one for outdoor
